Ubuntu 20.04 on Rpi 3 - Boot from NFS root [ANSWERED]
Posted: Wed May 27, 2020 4:52 pm
Good afternoon
After losing yet another (Raspbian) system to a corrupted SD card I've had enough. I have a system running happily off SSD and that is very straight forward, however, I have decided that for my usage profiles the logical path to take is to boot via NFS mounted root volumes. This seems a *way* more flexible and efficient method to follow. The reason I say this it seems to me that using an SSD requires 1 per Pi which given that the smallest size I can buy now is 120G is horrendously wasteful. It seems to me that if I mount from NFS, I can fit 15 pi root disks on one SSD. Regardless I will explore the theory and see how reliable it is.
Now - on Pi with Raspian I have found 3 different tutorials which are consistent enough that I believe it's clear how to do it - basically mount the root volume on a host and amend 1 line in /boot/cmdline.txt to reference the NFS volume and set IP address.
However, when I search for Ubuntu examples, the answers are more diverse and referring to PXE boot etc. I suspect that it's because the examples are not Pi based. Can someone please confirm if Ubuntu is fundamentally the same as Raspbian in this context? It seems there are similar (ish) boot files in Ubuntu - is that the right direction?
I will crack on with Raspbian anyway, but good to have the option as a couple of things I have are happier on Ubuntu.
TIA
Mike
[ANSWERED] by waveform in #UBUNTU IRC - tl;dr - not currently supported due to u-boot issues. Will proceed with Raspian/ RPOS and see how that goes while waiting for official UB network boot support
Well. It's up finally - pi3 booted new raspian 64 bit on an nfs root. Definitely the way forward so still very much interested in being able to do the same with Ubuntu...
TIA
Mike
