RPi2: Cannot get onboard ethernet to work on Ubuntu 20.04
Posted: Sun May 03, 2020 6:49 am
I've been trying to setup Ubuntu Server 20.04 on my old RPi2 but I couldn't seem to get the ethernet port to work. The eth0 keep showing down state I've ran out of idea or general Google support. Hopefully someone here can point me to the right direction to further trouble shoot this issue. Thank you.
Background:
I'm very new to Ubuntu 20.04, I believe since 18 networking needs to be manually configure on netplan.
I've setup the netplan file and have generated and apply the setting, but only the wifi adapter works, wasn't able to get the eth0 to work.
Looks like a lot of people got the ethernet logical name wrong, but I've confirm it is eth0.
Ip link will show the eth0 as down
I've tried using ifup and ifdown to set the status of eth0, but I get the error below.
I've also set the interface for eth0 for ifup and ifdown.
Background:
01-netcfg.yaml
network:
version: 2
# renderer: networkd
renderer: NetworkManager
ethernets:
eth0:
optional: true
dhcp4: true
wifis:
wlan0:
optional: true
access-points:
"ssid":
password: "wirelesspassword"
dhcp4: trueCode: Select all
ubuntu@ubuntu:~$ sudo lshw -C network
*-usb:0
description: Ethernet interface
product: SMSC9512/9514 Fast Ethernet Adapter
vendor: Microchip Technology, Inc. (formerly SMSC)
physical id: 1
bus info: usb@1:1.1
logical name: eth0
version: 2.00
serial: b8:27:eb:1a:7e:52
capacity: 100Mbit/s
capabilities: usb-2.00 ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=smsc95xx driverversion=22-Aug-2005 duplex=half firmware=smsc95xx USB 2.0 Ethernet link=no maxpower=2mA multicast=yes port=MII speed=10Mbit/s
*-network
description: Wireless interface
physical id: 2
bus info: usb@1:1.5.1
logical name: wlan0
serial: 00:0f:60:05:65:5f
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rt2800usb driverversion=5.4.0-1008-raspi firmware=0.36 ip=192.168.1.133 link=yes multicast=yes wireless=IEEE 802.11Code: Select all
ubuntu@ubuntu:~$ ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
link/ether b8:27:eb:1a:7e:52 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
link/ether 00:0f:60:05:65:5f brd ff:ff:ff:ff:ff:ff
ubuntu@ubuntu:~$ ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b1:22:eb:1b:7e:42 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 1920 bytes 142164 (142.1 KB)
TX packets 1920 bytes 142164 (142.1 KB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.xxx netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::20f:66ff:fe06:666f prefixlen 64 scopeid 0x20<link>
ether 00:0f:66:66:66:5f txqueuelen 1000 (Ethernet)
RX packets 3490 bytes 851978 (851.9 KB)
TX packets 707 bytes 90662 (90.6 KB)
ubuntu@ubuntu:~$ ifup eth0
ifup: unknown interface eth0Code: Select all
/etc/network/interfaces.d/eth0
auto eth0
iface eht0 inet dhcp
