Page 2 of 2
Re: [URGENT] Adding Flash plug-in to Chromium - Ubuntu 19.10(aarch64) + MATE on RPi4
Posted: Thu Apr 30, 2020 2:52 pm
by graf_eberstein
Botspot wrote:
Wed Apr 29, 2020 9:59 pm
Yeah I don't think dpkg auto-installs dependencies. Maybe apt does, but IDK.
sudo apt install browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.deb
It just might, but...
$ sudo apt install ./browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.deb
Reading package lists... Done
Building dependency tree
Note, selecting 'browser-plugin-freshplayer-pepperflash' instead of './browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 browser-plugin-freshplayer-pepperflash : Depends: libavcodec-ffmpeg56 (>= 7:2.4) but it is not installable or
                                                   libavcodec-ffmpeg-extra56 (>= 7:2.4) but it is not installable
                                          Depends: libavutil-ffmpeg54 (>= 7:2.4) but it is not installable
                                          Depends: libevent-2.0-5 (>= 2.0.10-stable) but it is not installable
                                          Depends: libevent-pthreads-2.0-5 (>= 2.0.10-stable) but it is not installable
                                          Depends: libssl1.0.0 (>= 1.0.0) but it is not installable
                                          Depends: libva-x11-1 (>= 1.0.3) but it is not installable
                                          Depends: libva1 (>= 1.2.0) but it is not installable
                                          Recommends: pepperflashplugin-nonfree but it is not installable
E: Unable to correct problems, you have held broken packages.
I also tried against browser-plugin-freshplayer-pepperflash_0.3.5-1ubuntu7_arm64.deb:
s$ sudo apt install ./browser-plugin-freshplayer-pepperflash_0.3.5-1ubuntu7_arm64.deb
Note, selecting 'browser-plugin-freshplayer-pepperflash' instead of './browser-plugin-freshplayer-pepperflash_0.3.5-1ubuntu7_arm64.deb'
 browser-plugin-freshplayer-pepperflash : Depends: libavcodec57 (>= 7:3.4.1) but it is not installable or
                                                   libavcodec-extra57 (>= 7:3.4.1) but it is not installable
                                          Depends: libavutil55 (>= 7:3.4.1) but it is not installable
                                          Recommends: adobe-flashplugin but it is not installable
Since I have the three "depend" files, I'm going to see if I can install them through similar means. Stay tuned...
Posted: Fri May 01, 2020 7:49 pm
by graf_eberstein
No joy! :cry:
