GPIO configuration on Ubuntu
Posted: Thu Apr 16, 2020 7:15 am
by jaumepi
Hello, I turned from Raspbian to Ubuntu 19 32bit on my RPI4 because I need this distribution, downloaded officialy using the RPI Imager. I had a working pinout mapping on config.txt for the I2C and SPI display. Where is this config.txt file and how to map the GPIO in Ubuntu?
There is one config.txt file on /firmware/ path. Should I modify this file?
What are the proper steps to configure the GPIO? Thank you.
Re: GPIO configuration on Ubuntu
Posted: Thu Apr 16, 2020 8:18 am
by jamesh
Although downloaded via Imager, this is not an official Raspberry Pi distribution - the only one of those is Raspbian. This distro is provided by Canonical - we just allow it to be installed via our system.
So your question has been moved to the Ubuntu forum, where hopefully an more experience Ubuntu person will see it. Alternatively, Canonical do have their own forums.
Posted: Thu Apr 16, 2020 10:25 am
by waveform80
Yup, the boot partition is mounted under /boot/firmware on Ubuntu (for ... reasons). You should be able to stick whatever you normally have in config.txt there (or syscfg.txt or usercfg.txt which are included from config.txt on our images - have a look in README if you want a run-down of the various files).
Posted: Fri Apr 17, 2020 2:32 pm
by jaumepi
Thanks for the reply. I tried to modify firmware/config.txt, usrconfig.txt and also the config.txt at same location when havins raspi-config installed in Ubuntu Mate. Always the same result...
After modifiying the desired configuration and reboot, the RPI4 enter into a loop trying to boot: the color image blinks, and immediately turns off. Then boot again, a blink of the colored image, turn off... and so on.
The configuration works perfectly in Raspbian, and it looks like:
#i2c, i2s, spi... are deactivated
dtoverlay=i2c-gpio,bus=3,i2c_gpio_sda=23,i2c_gpio_scl=24,i2c_gpio_delay_us=2
# DPI Video Setup
dtoverlay=dpi18
overscan_left=0
overscan_right=0
overscan_top=0
overscan_bottom=0
framebuffer_width=854
framebuffer_height=480
enable_dpi_lcd=1
display_default_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=458773
hdmi_timings=854 0 14 4 12 480 0 2 3 9 0 0 0 60 0 32000000 3
Posted: Tue Apr 21, 2020 12:26 pm
by evdokimosk
Dear jaumepi,
I encountered the same issue after modifying the usrconfig.txt.
Have you found a solution to this?
Thanks for sharing in case you have a promising solution.
Evdokimos
Posted: Thu Apr 23, 2020 7:03 pm
by jaumepi
It's the same behaviour if config or usrconfig.txt, yes.
I think it's a general problem when you install ubuntu and quite easy to reproduce....
But no solution yet... Any help would be appreciated. Thanks
Posted: Thu Apr 30, 2020 8:54 pm
by waveform80
I have a nasty feeling this is a u-boot incompatibility with DPI displays. I've got one on order and will try and reproduce (and debug!) once it arrives. For now, do feel free to file a bug for this against the u-boot package on Launchpad and let me know the reference as this is definitely something we want to make sure works!
Thanks,
Dave.
Posted: Fri May 01, 2020 8:32 am
by evdokimosk
Dear Dave,
I have reported a bug as you suggested with the bug reference Bug #1876265
Hope this helps,
Evdokimos
Posted: Fri May 01, 2020 10:41 am
by waveform80
Dear Dave,
Hope this helps,
Evdokimos
Excellent, thank you - that's going straight on the list of bugs I'm tracking this cycle. Will see what I can find out when the hardware arrives.
Posted: Sat May 23, 2020 11:42 am
by evdokimosk
Dear Dave,
as I am about to decide about a RPI 4 project between Raspbian or Ubuntu (I would like to use Ubuntu) where the DPI18 issue is critical, I would like to ask you if you have any time plan about the bug fix. My intention is not to push in anyway, but just to see if I should postpone my decision a bit more.
Thank you for you efforts,
Evdokimos
Dear Dave,
Hope this helps,
Evdokimos
