I have a Waveshare OV2710 2MP USB Camera attached to Raspberry Pi (it is 2 / Model B, but tested this also on 3 and 4 too with no difference)...
All I wanted is to get a real-time video stream on screen, so I run mplayer in TV mode (tried cheese and vlc, but they are way too resource hungry to run smoothly)...
The problem is that the stream has no colors - all are shades of green... (checking the same camera on my Fedora desktop shows that the problem not with the camera)
After a lot of search I came across guvcview and qv4l2 and was able to configure the image to something bearable (has harsh red and green colors but in between there are true - or near true - colors too), however wasn't able to keep those configuration over restart or camera remove and wasn't able to configure mplayer the same way...
I have Ubuntu MATE (latest) on the raspberry, and it's screen colors are look OK...
So some questions that I have:
1. Obviously the why? Why green shades?
2. There are other software I should try instead of mplayer?
3. There is a way to pass configuration from guvcview or qv4l2 to mplayer to get something better?
4. A replacement camera I should buy if nothing works with this one? I need a 'naked' camera, that has no plastic box, but the PCB and the lens so I can stick it to the flat inner wall of a box...
Thank you!
