DerJP
Cannot connect to Wi-Fi with Ubuntu 18.04
Sun Feb 16, 2020 4:42 pm
I've been having this issue with my 4GB Raspberry Pi 4B since I got it and I hope someone could have an idea. I tried everything I could find online but nothing resolved my issue so far.
I flashed the following Ubuntu 18.04 image on my 128GB SanDisk SD card: https://ubuntu.com/download/raspberry-p ... m64+raspi3 from https://ubuntu.com/download/raspberry-pi (dont be tricked by the "raspi3" in the url, it's the link they provide for the Pi 4 image).
Everything works fine on my Pi, I can login normally, manage packages, and use all other features.
The only thing that isn't working is finding wifi networks. I search for all available networks by using sudo iwlist wlan0 scan. It searches for a few seconds and then returns wlan0 No scan results.
What I tried so far:
  • Tried the newest release (Ubuntu 19.10), which had the same issue
  • Reinstalling the Ubuntu image
  • Using sudo for all commands used
  • Setting the wifi region to my country (DE)
  • Changing my wifi frequency bands from 13 to 9 or less in my router settings, since non-EU systems sometimes have issues with these bands
  • Using rfkill to make sure that the wireless card isn't blocked
all to no avail, unfortunately.
Thanks for your help!
Re: Cannot connect to Wi-Fi with Ubuntu 18.04
Sun Feb 16, 2020 5:13 pm
Does it work under Raspbian? If not then there is a HW problem, if it does work then is an Ubuntu problem. There are other threads in this subsection on Ubuntu wireless. I guess you might need a more recent version.
kerry_s
Sun Feb 16, 2020 6:36 pm
this is the fix:
https://askubuntu.com/questions/1122757 ... -and-above
same fix works for 19.10
the sound stutter can be fixed with this:
sudo nano /etc/pulse/default.pa
look for:
load-module module-udev-detect
change to:
load-module module-udev-detect tsched=0
if i remember right, everything else works it's just slower than say raspbian lite + "whatever desktop"
the 32bit works better than the 64bit for 19.10 install.
if using gnome, select the xorg option in gdm login.
DerJP
Mon Feb 17, 2020 3:51 pm
this is the fix:
look for:
change to:
Thank you a lot, this is exactly what was wrong. All networks show up now.
murraybd
Mon Feb 17, 2020 3:55 pm
What type of wireless network are you trying to connect to? 802.11b? 802.11n? I ask as there is an issue with the firmware which we include with both 18.04.4 and 19.10.1 and networks which are only 802.11ac.
Software Engineer at Canonical
Ubuntu Core Developer
Return to “Ubuntu”
