ElConcombritos
Rotate display with ubuntu 19.10
Fri Feb 14, 2020 8:43 am
Hello, i need to rotate the display on a rpi4 using ubuntu 19.10. I tried by adding some stuff in usercfg.txt, which seems to be the new config file on this version but i don't manage to make this work.
Here is what i put in usercfg :
disable_overscan=1
display_rotate=1
dtoverlay=vc4-fkms-v3d
With this configuration, the screen is rotated for the boot screen, but when it's done, the desktop appear in the background and the boot code stay in front of everything in a weird way.
I also tried xrandr but it split the screen in two part like this :
https://zupimages.net/viewer.php?id=20/07/uvvq.jpg
How can i achieve to rotate the display and put in portrait mode ?
Return to “Ubuntu”
