Flow
[Pi 4] - Issue with the integrated wifi after 12hours
Mon Jan 13, 2020 8:19 am
I've my new Pi4 since this week. I've successed to connect my pi to my wifi to do my server.
but it appears that after 12h, the integrated wifi go down and i have to reboot the Pi.
I've found some forum post from the past with the similar issue but without real solution (i.e. https://raspberrypi.stackexchange.com/q ... t-12-hours)
Is there a configuration file to change to keep my wifi alive ?
Thank you.
Flow
WolfRamiO
Re: [Pi 4] - Issue with the integrated wifi after 12hours
Mon Jan 13, 2020 8:58 am
Did you run and apply rpi-update at anytime? If not You must then report if issue still exist.
Flow
Mon Jan 13, 2020 9:34 am
thx for the reply.
Unfortunatly, the rpi-update is not found either via command line, either via the apt get install command
I'm under ubuntu-server 19.10 raspi version.
I've updated the wifi firmware via : https://wiki.ubuntu.com/ARM/RaspberryPi ... 5#Packages
I've rebooted my PI4.
we'll see !
Thanks.
mikgla
Wed Jan 15, 2020 10:07 am
Run and apply rpi-update from Raspbian and reboot to apply the update. Then switch back to your Ubuntu SD card.
Return to “Ubuntu”
