WAWII
RPi 4 Ubuntu and No Network functionility
Sun Dec 08, 2019 10:09 pm
OK, I've tried Ubuntu Server 19.10 & 19.10.1 64 and 32 bit (as well as Open Media Vault) and the same issue on all attempts. The Pi didn't connect to the network over Wired or WiFi. It won't update, or install anything it needs to get from repositories, I can't ping, and when I look at devices connected to my network it's just not there.
Raspbian and LibreELEC both work and connect to the Internet just fine. What am I missing? I've updated the Pi's BIOS but that didn't help either.
Errors are Failed to Fetch and Unable to Fetch.
What am I missing, or is there PI compatibility issues?
wuwentao
Re: RPi 4 Ubuntu and No Network functionility
Mon Dec 09, 2019 2:56 am
use default 19.10 image , default username/password, wired connection is DHCP client, connect to my AP with ethernet.
it will works well, eth0 can get IP address with DHCP client.
ubuntu@raspberrypi:~$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=19.10
DISTRIB_CODENAME=eoan
DISTRIB_DESCRIPTION="Ubuntu 19.10"
ubuntu@raspberrypi:~$ uname -a
Linux raspberrypi 5.3.0-1014-raspi2 #16-Ubuntu SMP Tue Nov 26 11:18:23 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux
ubuntu@raspberrypi:~$ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.123 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::xxxx:xxxx:xxxx:xxxx prefixlen 64 scopeid 0x20<link>
ether dc:a6:xx:xx:xx:xx txqueuelen 1000 (Ethernet)
RX packets 391 bytes 53581 (53.5 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 385 bytes 41191 (41.1 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
mikgla
Tue Dec 10, 2019 10:49 am
Before you install the new Ubuntu Server image you should first swop SD card and use Raspbian to install the latest firmware by using the following commands:
1. sudo apt update && sudo apt dist-upgrade -y
2. sudo rpi-update
3. sudo rpi-eeprom-update -a
Then insert the Ubuntu SD card (make sure you have the ethernet cable connected) and the power-up your RPI4.
Rolly
Mon Dec 16, 2019 5:57 pm
Having done these steps, on reinstalling Ubuntu Server 64, & trying to install a GUI (X/L/Kbuntu-dsktop), the installation goes OK, but no desktop.
WAWII
Tue Dec 17, 2019 9:25 pm
2. sudo rpi-update
Thanks, I've tried that and still get the:
"Unable to fetch" errors while trying to install Xubuntu-Desktop.
phase
Tue Dec 17, 2019 9:32 pm
make shore you are "root" user..
it may be that the unattended updater is running..
try rebooting a couple of times then try the install process over again..also check your timezone/clock is correct..
is it happening at the start failing to get /connect to the Ubuntu servers to download the packages..??
WAWII
Wed Dec 18, 2019 3:32 am
Yes, I am root.
I've rebooted several times, and each time the date is indeed incorrect. setting the date/time works, but each reboot it does back to the old date
Yes fresh start and still no network connections (scaned IP's from other conputers and no PI ot it's MAC address connection).
phase
Wed Dec 18, 2019 9:42 am
which image did you flash to your sd-card and do you already have other desktops installed onto the sd-card
pls flash the 64 bit image from here and pls use Ethernet to start with....
http://cdimage.ubuntu.com/ubuntu-server ... /20191203/
once flash run this code to update it
apt update && apt-full-upgrade && apt dist-upgrade
reboot
EDIT:: 1:: as follows=====below
apt install xubuntu-desktop^  slick-greeter
or
apt install xubuntu-core^ slick-greeter
copy paste that above..it should work now
WAWII
Wed Dec 18, 2019 2:57 pm
try
apt install xfce4
I flashed a fresh card with ubuntu-19.10.1-preinstalled-server-arm64+raspi3.img from https://ubuntu.com/download/raspberry-pi
I had an Ethernet cable connected to the Pi while loading and after and it still doesn't see the network.
Both the Raspbian and the LibreELEC install load and run as well as see the Internet.
I will try this Daily download and see if it works and let you know.
WAWII
Wed Dec 18, 2019 3:22 pm
After installing the Ubuntu Server 19.10.1 (Eoan Ermine) Daily Build with Eathernet cable connected, and logging in and changing the root PW, I try the sugest command:
sudo apt update && apt-full-upgrade && apt dist-upgrade
What is returned is:
Err:1 http://ports.ubuntu.com/ubuntu-ports eoan InRelease
Temporary failure resolving 'ports.ubuntu.com'
Err:2 http://ports.ubuntu.com/ubuntu-ports eoan-updates InRelease
Err:3 http://ports.ubuntu.com/ubuntu-ports eoan-backports InRelease
Err:4 http://ports.ubuntu.com/ubuntu-ports eoan-security InRelease
Reading package list ... Done
Building dependency tree
All packages are upto date.
W: failed to fetch http://Ports.ubuntu.com/ .................
W: Some index files failed to download. they have been ignored, ............
I scanned my network, and I don't see the Pi connected.
phase
Wed Dec 18, 2019 6:28 pm
i think you should check your cabling..
however if you do manage to install xubuntu-desktop
then after it has installed and you are back at the command prompt before you reboot it remove the standard greeter
apt remove lightdm-gtk-greeter
reboot
this will after a reboot bring up the login screen
WAWII
Wed Dec 18, 2019 10:11 pm
No cabling issues, the cable works on the other computer, and I pulled the Ubuntu card, slid in the Rasbian card in with no change in the cable and I have both WiFi and Ethernet connections.
phase
Wed Dec 18, 2019 11:59 pm
try these commands from the command line pls in line one after the other...
sudo dhclient -v
sudo dhclient -v -r
hopefully that will renew the connection between your rpi-4 and the router/switch ..etc..etc
now try updating the updates..have a read here..
https://www.computerhope.com/unix/dhclient.htm
WAWII
Thu Dec 19, 2019 5:07 pm
OK, THANKS! Progress is being made.
On the Pi Ubuntu Server release:
sudo dhclient -v and sudo dhclient -v -r only got me IP addresses (both Wifi and Ethernet), but no network connection.
I used sudo dhclient -4 -v and got connection (Ethernet only) and was able to run the update.
My Internet supplier isn't providing IPV6 address, but their modem does hand them out internally, perhaps this is the problem?
On the "http://cdimage.ubuntu.com/ubuntu-server ... /20191203/" download the sudo dhclient -v got me IP addresses and connections on Ethernet, while the sudo dhclient -v -r killed the connection.
Unable to get the Wifi to get a IPV4 address, as it keeps getting an IPV6 address with no connection.
With the Ethernet connection now established I successfully ran the sudo apt update && apt-full-upgrade && apt dist-upgrade command.
After rebooting I still had to run the sudo dhclient -v command to get a network connection on Ethernet.
I then ran the sudo apt install xubuntu-desktop^ slick-greeter command to install the xUbuntu Desktop.
After the install completes I issue the reboot, and it does, but after the normal ubuntu text is done I get a black screen.
phase
Thu Dec 19, 2019 11:37 pm
once it boot`s to the blank screen pres these keys
.press
CTRL+ALT + F2
login as root
sudo su
and run the below code...
reboot
and after it reboots you should have a desktop...
furthermore i have not encountered your issue before but there seems to be some issue with your isp i think..
WAWII
Fri Dec 20, 2019 4:31 pm
Yep, Thanks.
CTRL+ALT + F2
Logged in
sudo dhclient -v
(to get network access)
sudo su
reboot
The reboot was slow, but It did and I got a GUI Login Screen. Once logged in I had to open a terminal and issue the dhclient -v command to get a connection.
Yea, kind of strange on the only wanting to connect thru IPV6. Guess I need to check with my SIP and see if I should be getting an IPV6 address, or find a way to disable it (no obvious way on their modem to turn it off).
THANKS a lot for the help!
Will
WAWII
Sat Dec 21, 2019 3:10 pm
After running a dhclient -v wlan0 command and letting it work, I got 2G wireless connect-ability (no 5G ability). This also allows it to reconnect after rebooting without issuing the dhclient command again like I'm having to do with the Ethernet. So more progress.
phase
Sat Dec 21, 2019 3:32 pm
i dont know what is going on there...i have never encountered issue`s as such you have
do you connect directly to the gateway..
maybe you need to put a router in the series line and connect via the router...????
WAWII
Sat Dec 21, 2019 5:39 pm
Very strange indeed.
I've got the Ethernet connected to a switch, then to the ISP Modem/Router/Wifi, but I've now connected Wifi to both my ISP Wifi and my Wifi access point on 2G with no issues, just can't get 5G.
WAWII
Sun Dec 22, 2019 12:17 am
So to be sure I know what steps make it work, and what I had to do to get things like Ethernet and sound working, here is the complete list of steps I went thru after starting over with an Ubuntu Server install for the Raspberry 4 - 19.10.1 (http://cdimage.ubuntu.com/releases/19.1 ... pi3.img.xz).
sudo dhclient -v (To get Ethernet Connectivity)
sudo apt update && sudo apt upgrade -y
sudo apt install xubuntu-core^ slick-greeter
(Create /etc/lightdm/lightdm.conf)
sudo nano /etc/lightdm/lightdm.conf
(Add lines:)
[SeatDefaults]
greeter-session=slick-greeter
(Save and Exit)
sudo reboot
Once rebooted I can connect to a Wifi 2G Network fine, but the Ethernet Connection dosn't work unless you open a Terminal and Issue the "sudo dhclient -v" command
(to add the FireFox Browser Open a Terminal and issue the following command:)
sudo apt-get install firefox
(to add the LibreOffice Open a Terminal and issue the following command:)
sudo apt-get install libreoffice-common
(to add the VLC Media Player Open a Terminal and issue the following command:)
sudo apt-get install vlc
(to add the Synaptic Package Manager Open a Terminal and issue the following command:)
sudo apt-get install synaptic
(Now use Synaptic to install Software store)
(Now use Synaptic to install Update Manager)
(After each reboot to have Ethernet connectivity you will need to open a terminal and issue the "sudo dhclient -v" command).
(In /boot/firmware/usercfg.txt I added a line to allow sound on the HDMI monitor:
dtparam=audio=on. I accidentally found this while googling Raspberry Pi 4 sound driver)
phase
Sun Dec 22, 2019 9:53 am
something is not right with your network or maybe your board is faulty..
you should not have to issue the dhclient all the time...
even when i had xubuntu loadeed i did not have the issue..or for that matter 19.10...
i have done many installs with any op sys and never had ethernet problems..so i`m wondering ...it only leaves your entire network setup or your board..!!!
WAWII
Sun Dec 22, 2019 5:19 pm
Indeed, I need to get it and a monitor down to the ISP router and give it a try, and/or take it to a different ISP supplied location and give it a try.
phase
Mon Dec 23, 2019 1:23 am
do you use etcher to flash your media..sd-card..
what brand and size is your sd-card..???
WAWII
Wed Dec 25, 2019 2:36 am
Yes, I use Etcher. The SD cards are Samsung EVO Select UHS-I Class 10 32Gb (Green - Amazon).
Return to “Ubuntu”
