I've got a Raspberry Pi 4 4GB model running Ubuntu Server eoan 19.10. I'm trying to overclock the Pi to run at 2GHz, so I've modified the /boot/firmware/usrconfig.txt file to include the following lines:
# Place "config.txt" changes (dtparam, dtoverlay, disable_overscan, etc.) in
# this file. Please refer to the README file for a description of the various
# configuration files on the boot partition.
total_mem=3072 # Workaround to allow USB to work - see https://bugs.launchpad.net/ubuntu/+source/linux-raspi2/+bug/1848790
# Overclock
arm_freq=2000
over_voltage=5Here's the output of vcgencmd get_config int after overclocking. The only difference between this and the same command before overclocking is that arm_freq=1500 and the line over_voltage=5 is not present.
arm_64bit=1
arm_freq=2000
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=500
core_freq_min=500
device_tree_address=0x3000000
disable_commandline_tags=2
disable_l2cache=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
enable_gic=1
enable_uart=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_depth=16
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=500
gpu_freq_min=500
init_uart_clock=0x2dc6c00
lcd_frameraarm_64bit=1
arm_freq=2000
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=500
core_freq_min=500
disable_l2cache=1
enable_gic=1
enable_uart=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_swap=1
gpu_freq=500
gpu_freq_min=500
lcd_framerate=60
mask_gpu_interrupt0=1024
mask_gpu_interrupt1=0x10000
max_framebuffers=2
over_voltage=5
pause_burst_frames=1
program_serial_random=1
total_mem=3072
hdmi_force_cec_address:0=65535
hdmi_force_cec_address:1=65535
hdmi_pixel_freq_limit:0=0x11e1a300
hdmi_pixel_freq_limit:1=0x11e1a300
te=60
max_framebuffers=2
over_voltage=5
total_mem=3072
hdmi_pixel_freq_limit:1=0x11e1a300Code: Select all
Linux ubuntu 5.3.0-1008-raspi2 #9-Ubuntu SMP Fri Oct 18 13:26:35 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux
