Gavinmc42
Re: Ubuntu 19.10 for the Raspberry Pi 4 with a KVM-enabled kernel & Windows 10 guest
Thu Oct 31, 2019 2:58 am
Have you asked on the Ubuntu forums?
I'm dancing on Rainbows.
Cob
Thu Oct 31, 2019 11:25 am
Tried this? linux-image-5.3.0-1008-raspi2_5.3.0-1008.9+kvm_arm64 and linux-image-5.3.0-1008-raspi2_5.3.0-1008.9+kvm_armhf
https://bugs.launchpad.net/ubuntu/+sour ... comments/1
pooky
Thu Oct 31, 2019 11:56 am
It's works !
Now my kernel is:
Linux ubuntu 5.3.0-1008-raspi2 #9+kvm SMP Wed Oct 23 15:33:01 CST 2019 aarch64 aarch64 aarch64 GNU/Linux
Thank you for share!
BRX7
Sat Nov 02, 2019 11:06 pm
ok I have run the script on Gentoopi64 RPI4 4GB,
I get a message saying GTK initialization failed, is this because I am running it through a rdp connection to my pi?
KuroRyu
Mon Nov 11, 2019 1:00 pm
I am trying to follow the tutorial but I am facing some issues during the process.
When I have booted the image, there seems to be some problem with libc. I can not update the system at all.
ubuntu@ubuntu:/$ apt-get update
apt-get: /lib/aarch64-linux-gnu/libc.so.6: version `GLIBC_2.30' not found (required by /lib/aarch64-linux-gnu/libudev.so.1)
ubuntu@ubuntu:/$ apt-get upgrade
How can I solve this?
Gavinmc42
Thu Nov 14, 2019 10:52 am
Is Ubuntu now the most up to date OS for Pi3/4?
Kernel 5.3 on aarch64?
XperfectTR
Wed Dec 04, 2019 2:42 pm
Following the same steps I did with orange pi 3.but the screen does not come with virtualization.
It works without virtualization.
What is the reason?
gilius2k15
Wed Dec 25, 2019 9:51 pm
Windows 10 Lite version 1.0 for Raspberry Pi 3/4 has been released today:
https://discourse.pi64.win/t/woalite-re ... rry-pi/457
It includes simplified instructions for RPi4 KVM using the WOALight install.wim with built-in drivers. Basically, everything is done remotely from a Windows 10 PC besides copying the bios file to the Gentoo desktop - see instructions via the above link.
ChasTech
Thu Jan 02, 2020 9:26 pm
Nice! When my RPi4 accessories arrive later tomorrow, I'll try this out! Considering I have the 4GB RAM version this should be good :D :D
If apples give you apple pie, bananas give you banana pie, pears give you pear pie, and cherries give you cherry pie, then what do raspberries give you?
A Raspberry Pi :lol:
AveryFreeman
Wed Jan 08, 2020 5:10 pm
Three questions:
Which version of Windows IOT are you running? 19035 is supposed to have major upgrades for KVM ARM
Is the ARM version of Windows only capable of running appx containers? (UWP apps - like windows store apps)
Have you been able to use KVM 5.3? 5.3 kernel is supposed to have major updates for KVM ARM - 5.5.1 builds on that (was just looking at source in GitHub)
Thanks!
Botspot
Fri Jan 10, 2020 12:51 am
Could someone share an img file of this setup?
Want to make your own Raspbian image?
  • Hard way: Mess with confusing terminal commands.
  • Easy way: Let Pi-Power-Tools do it all for you!
Boot your image in a VM, Flash from the Internet at top speed, Mount (to drop files in), Edit partitions, Shrink/Expand, Repair, and more. Enjoy! :)
https://github.com/Botspot/Pi-Power-Tools
Return to “Ubuntu”
