Docker Raspberry Pi 4B ARM64 Ubuntu Image Builder
Posted: Mon Jul 29, 2019 9:56 pm
by satadru
I spent a couple of days hacking together a docker setup to create flashable Ubuntu images for the Raspberry Pi 4B which cross-compile current Raspberry Pi kernels and integrate them into the image.
Note that this runs in privileged mode, so you're going to have to use this on your own servers.
https://github.com/satmandu/docker-rpi4-imagebuilder/
I'm using an ARM64 RPI3 Ubuntu Server 19.10 (Eoan Ermine) Daily Build as a base image, which I get from here:
http://cdimage.ubuntu.com/ubuntu-server ... d/current/
I have the resultant images booting on a 4GB Raspberry Pi 4B, without having to remove initramfs-tools or flash-kernel, and I can see all 4Gb of RAM on the 4Gb RPI 4B.
Instructions were cobbled together from these sites:
https://jamesachambers.com/raspberry-pi ... ion-guide/
https://blog.cloudkernels.net/posts/rpi4-64bit-image/
https://andrei.gherzan.ro/linux/raspbian-rpi-64/
https://andrei.gherzan.ro/linux/raspbian-rpi4-64/
https://github.com/sakaki-/bcm2711-kernel-bis
The docker image is itself hacked off of https://github.com/tsaarni/docker-deb-builder .
Feel free to fork away, or send in useful pull requests.
Re: Docker Raspberry Pi 4B ARM64 Ubuntu Image Builder
Posted: Tue Jul 30, 2019 4:16 pm
by o635789
Wow, all 4GB are usable? Thank you very much for the great work! I'll try it out.
Posted: Tue Jul 30, 2019 9:48 pm
by sakaki
Nice work satadru!
Can you access the USB ports (to read data from a thumb drive etc.) with the full 4GiB enabled? I found I had to set total_mem=3072 at most, even with a rpi-4.19.y kernel built off the tip today; see also this commit comment.
Best, sakaki
Posted: Wed Jul 31, 2019 12:11 am
by cjan
does VC6 work?
Posted: Wed Jul 31, 2019 8:43 pm
by GuyOthersome
Is it possible to do this with 18.04.2? Or is this script exclusive to 19.10?
Posted: Wed Jul 31, 2019 9:59 pm
by gilius2k15
I don't really understand the concept of this in terms of dockers and server/privileged mode? What has that got to do with making an Ubuntu image for the Raspberry Pi4?
Does the GUI work - or do you get black screen with mouse cursor?
Posted: Sun Aug 04, 2019 12:44 pm
by gilius2k15
Had quite a lot of errors and reports of missing packages when I got to this step:
docker build -t docker-rpi4-imagebuilder:19.10 -f Dockerfile-ubuntu-19.10 .
Not sure what host Os and perquisites are recommended?
Posted: Tue Aug 06, 2019 2:00 pm
by gilius2k15
It seems like this needs an AMD64 host because one package is not available on ARM64 Linux:
https://packages.ubuntu.com/bionic/cpp- ... -linux-gnu
Posted: Tue Aug 06, 2019 4:30 pm
by gilius2k15
Mine got stuck here so I submitted a new issue:
https://github.com/satmandu/docker-rpi4 ... /issues/14
Screenshot from 2019-08-06 15-53-17.jpg (117.2 KiB) Viewed 8051 times
Posted: Thu Aug 08, 2019 7:03 am
by gilius2k15
I finally got it working - but there's no KVM enabled in the kernel! :x
There's only 3GB RAM enabled at the moment as per sakaki's method.
VC4 seems turned off but should work because of Ubuntu 19.10 having Mesa 19.1
Posted: Mon Aug 19, 2019 3:04 pm
by chideki
can confirm doing this with bionic. all 4gb working . no need to remove kernel flash etc ... compiling took 6minutes on vmware. rasp pi 4 rouns smoth so far.
Posted: Mon Aug 19, 2019 6:23 pm
by GuyOthersome
I'm unable to build 18.04 on macOS Mojave...are there instructions on how to do this? I thought just using "docker-rpi4-imagebuilder:18.04" was supposed to work? Am I blind and not seeing what I'm supposed to do in the instructions?
Posted: Mon Aug 19, 2019 11:00 pm
by blu33agl3
For everyone try
Ubuntu Bionic
Raspberry Pi 4B
https://drive.ddnsthailand.com/index.ph ... zBg6aXm2Ad
password: Bondon1234
mirror 1: https://yadi.sk/d/fXsUZY4qaryEfQ
mirror 2: https://bit.ly/2HeT12J
user/password for login : ubuntu/ubuntu
Posted: Thu Aug 22, 2019 8:35 pm
by gilius2k15
Does it have KVM enabled?
Posted: Thu Aug 22, 2019 8:47 pm
by sparticle
This is great but is only 1GB is there an updated version that does not suffer from the 1gb problem and can see 3072 + working USB ports?
Cheers
Spart
Posted: Fri Aug 23, 2019 9:00 am
by sparticle
Can you post the recipe or a lin kto the image file. Is this 18.04 based?
I am looking for a 18.04 LTS image that works with the 4GB Pi 4B.
Cheers
Spart
Posted: Fri Aug 23, 2019 9:45 am
by sparticle
When trying this with Bionic with the following command line: git pull ; time default_base_dist="bionic" base_dist=bionic ./build-image
This is what I get. It successfully downloads the rpi3 image then falls over .
Successfully tagged docker-rpi4-imagebuilder-v4:18.04
            "docker-rpi4-imagebuilder-v4:18.04"
            "LastTagTime": "2019-08-23T10:32:02.901738619+01:00"
* Downloading bionic-preinstalled-server-arm64+raspi3.img.xz .
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  441M  100  441M    0     0  3600k      0  0:02:05  0:02:05 --:--:-- 4088k
* Checking image hash.
local: 754844708a857073e4ebc18efa6caeae3954fbb1
current: 754844708a857073e4ebc18efa6caeae3954fbb1
* bionic-preinstalled-server-arm64+raspi3.img.xz hash verified.
* Now have local bionic-preinstalled-server-arm64+raspi3.img.xz .
* Extracting /home/sparticle/docker-rpi4-imagebuilder/bionic-preinstalled-server-arm64+raspi3.img .
/home/sparticle/docker-rpi4-imagebuilder/bionic-preinstalled-server-arm64+raspi3.img.xz (1/1)
  100 %     441.1 MiB / 2,404.5 MiB = 0.183    50 MiB/s       0:48
Creating docker cache volume rpi4-imagebuilder-cache if it does not exist.
Running build in docker:
rm -f /home/sparticle/docker-rpi4-imagebuilder/build.cid ; docker run -dt -e BUILDHOST_ARCH=x86_64 -v /dev:/dev --privileged -dt -v /home/sparticle/docker-rpi4-imagebuilder:/source-ro:ro -v /home/sparticle/docker-rpi4-imagebuilder/output:/output -v /home/sparticle/docker-rpi4-imagebuilder/in-image-script.sh:/in-image-script.sh:ro -e USER=0 -e GROUP=0 --rm -e kernel_branch=rpi-4.19.y -e kernelgitrepo=https://github.com/raspberrypi/linux.git -e CCACHE_DIR=/cache/ccache -v rpi4-imagebuilder-cache:/cache -e src_cache=/cache/src_cache -e apt_cache=/cache/apt_cache -e workdir=/build/source -e base_url=http://cdimage.ubuntu.com/ubuntu-server/bionic/daily-preinstalled/current/ -e base_image=bionic-preinstalled-server-arm64+raspi3.img.xz -e base_dist=bionic -v /home/sparticle/docker-rpi4-imagebuilder/bionic-preinstalled-server-arm64+raspi3.img.xz:/bionic-preinstalled-server-arm64+raspi3.img.xz --tmpfs /flag --tmpfs /tmp -e COLS=112 --cidfile=/home/sparticle/docker-rpi4-imagebuilder/build.cid  docker-rpi4-imagebuilder-v4:18.04 /bin/bash -c "/in-image-script.sh ;  [ -e "/tmp/build.log" ] && (ls -crGg /flag > /tmp/build_fail_status.log ; grep "" /flag/* >> /tmp/build_fail_status.log ; mv /tmp/build.log /tmp/build_fail.log; cp /tmp/*.log /output/ ; chown $USER:$GROUP /output/*.log;  )  || exit 0"
c15dfadea4c99afe35c4077475acc0abb7dbc9a86eff3f517b30da761fda9ee4
cat: '/proc/31406/task/*/children': No such file or directory
Using sudo to renice build container to lowest priority:
(Some renices are expected to fail.)
Note that the command to open a shell into this docker instance would be:
docker exec -it c15dfadea4c99afe35c4077475acc0abb7dbc9a86eff3f517b30da761fda9ee4 /bin/bash
Or run ./shellbuild from this directory.
Tailing build log:
secondary config      (readonly)    /etc/ccache.conf
cache hit (direct)                     0
cache hit (preprocessed)               0
cache miss                             0
cache hit rate                      0.00 %
cleanups performed                     0
files in cache                         0
cache size                           0.0 kB
Performing cache volume apt autoclean.
        Started: base_image_check [ ]
        Started: compiler_setup [ ]
* Checking for downloaded bionic-preinstalled-server-arm64+raspi3.img.xz .
        Started: utility_scripts [ ]
* Downloaded bionic-preinstalled-server-arm64+raspi3.img.xz exists.
        utility_scripts waits for: image_mount [/]
        Done: base_image_check [X]
/in-image-script.sh: line 142: ts: command not found
        Started: git_get.armstub8-gic [ ]
        image_mount waits for: image_extract [/]
                                                           image_apt_installs waits for: arm64_chroot_setup [/]
        Started: git_get.kernelbuild_setup [ ]
                                                       rpi_cmdline_txt_configuration waits for: image_mount [/]
                                                          wifi_firmware_modification waits for: image_mount [/]
                                                        rpi_config_txt_configuration waits for: image_mount [/]
        Started: andrei_gherzan_uboot_fork [ ]
        Started: git_get.andrei_gherzan_uboot_fork [ ]
        Started: git_get.rpi_userland [ ]
        Started: git_get.non-free_firmware [ ]
        Started: git_get.rpi_firmware [ ]
                                                            first_boot_scripts_setup waits for: image_mount [/]
🤔 Build failed. Tailing output/build_fail.log :   😬
        image_extract waits for: base_image_check [/]
        added_scripts waits for: image_mount [/]
        arm64_chroot_setup waits for: image_mount [/]
real	10m0.900s
user	0m44.920s
sys	0m8.997s
build-fail-status.log says this:
-rw-r--r-- 1 0 Aug 23 09:35 wait.wifi_firmware_modification_for_image_mount
-rw-r--r-- 1 0 Aug 23 09:35 wait.utility_scripts_for_image_mount
-rw-r--r-- 1 0 Aug 23 09:35 wait.rpi_config_txt_configuration_for_image_mount
-rw-r--r-- 1 0 Aug 23 09:35 wait.rpi_cmdline_txt_configuration_for_image_mount
-rw-r--r-- 1 0 Aug 23 09:35 wait.image_mount_for_image_extract
-rw-r--r-- 1 0 Aug 23 09:35 wait.image_extract_for_base_image_check
-rw-r--r-- 1 0 Aug 23 09:35 wait.image_apt_installs_for_arm64_chroot_setup
-rw-r--r-- 1 0 Aug 23 09:35 wait.first_boot_scripts_setup_for_image_mount
-rw-r--r-- 1 0 Aug 23 09:35 wait.arm64_chroot_setup_for_image_mount
-rw-r--r-- 1 0 Aug 23 09:35 wait.added_scripts_for_image_mount
-rw-r--r-- 1 3 Aug 23 09:35 start.utility_scripts
-rw-r--r-- 1 2 Aug 23 09:35 start.spinnerwait
-rw-r--r-- 1 3 Aug 23 09:35 start.git_get.rpi_userland
-rw-r--r-- 1 3 Aug 23 09:35 start.git_get.rpi_firmware
-rw-r--r-- 1 3 Aug 23 09:35 start.git_get.non-free_firmware
-rw-r--r-- 1 3 Aug 23 09:35 start.git_get.kernelbuild_setup
-rw-r--r-- 1 3 Aug 23 09:35 start.git_get.armstub8-gic
-rw-r--r-- 1 3 Aug 23 09:35 start.git_get.andrei_gherzan_uboot_fork
-rw-r--r-- 1 3 Aug 23 09:35 start.compiler_setup
-rw-r--r-- 1 3 Aug 23 09:35 start.andrei_gherzan_uboot_fork
-rw-r--r-- 1 2 Aug 23 09:35 main
-rw-r--r-- 1 2 Aug 23 09:35 done.ok_to_umount_image_after_build
-rw-r--r-- 1 2 Aug 23 09:35 done.ok_to_exit_container_after_build
-rw-r--r-- 1 2 Aug 23 09:35 done.ok_to_continue_after_mount_image
-rw-r--r-- 1 2 Aug 23 09:35 done.ok_to_continue_after_here
-rw-r--r-- 1 2 Aug 23 09:35 done.base_image_check
/flag/done.base_image_check:6
/flag/done.ok_to_continue_after_here:1
/flag/done.ok_to_continue_after_mount_image:1
/flag/done.ok_to_exit_container_after_build:1
/flag/done.ok_to_umount_image_after_build:1
/flag/main:6
/flag/start.andrei_gherzan_uboot_fork:59
/flag/start.compiler_setup:32
/flag/start.git_get.andrei_gherzan_uboot_fork:59
/flag/start.git_get.armstub8-gic:53
/flag/start.git_get.kernelbuild_setup:60
/flag/start.git_get.non-free_firmware:56
/flag/start.git_get.rpi_firmware:52
/flag/start.git_get.rpi_userland:58
/flag/start.spinnerwait:6
/flag/start.utility_scripts:33
Any help appreciated.
Cheers
Spart
