loboris
Re: New Ubuntu Mate arm64 RaspberryPi 4 image (minimal and server images also available)
Wed Apr 28, 2021 2:56 pm
forbiddenera wrote:
Wed Apr 28, 2021 4:37 am
Found this image looking for a 'minimal' install as I want to get the system as lean as possible and booting into a chromium kiosk as quick as possible, was hoping to setup the most minimal system then install X and lightdm/chromium for kiosk mode as currently, I was developing on a Pi4B with the official 20.04, using lightdm, though the Chromium snap seems to be missing some features? WebUSB/WebSerial/WebBT do not work.. was going to compile myself, you say your version 'works better' but don't clarify..?
curious if MATE is a better option than lightdm. As I'm using kiosk mode fullscreen, I don't actually need a window manager, desktop environment or any other GUI apps besides Chromium.
Ideally I want to get booted to full screen Chromium in under 20 seconds. I'm not against using some sort of hibernation tricks even but ideally would rather just get it light enough to not require that.
Also, does this use u-boot or what? On my pi4b with regular Ubuntu, I had to recompile u-boot for two reasons - to eliminate the boot delay and prevent it from spitting anything to the UART console (which will be used otherwise)
You've posted a lot of questions, I don't have the time to answer in more detailes now, here are just a short notes.
Mate is a Desktop Environment and lightdm is a display manager, they cannot be compared.
There are some simple ways to run Chromium in kiosk mode, I've done it long time ago on RPi 1. You don't need to install any desktop environment. There are quite a few guides on Internet, search... (example)
This image uses the standard RPi kernel, there is no initramfs (and it is not needed).
There is no u-boot also as it is not needed.
For overclock just uncomment in config.txt, notthing else is needed.
Do not do things you are not absolutelly sure are needed.
NicknDi
Fri Apr 30, 2021 5:18 pm
Audio configuration?
Which file(s) do I need to edit, and how, so that default sound output uses usb soundcard and input uses usb webcam microphone? Currently we have to open the sound settings after every reboot and set the output to the usb soundcard. (The webcam is usually set as input/microphone, but it would be good to know which file determines that too.)
I've looked at multiple posts, but many are out of date and anyway for straight Raspberry OS. The /etc/modprobe.d/alsa-base-conf file on this image looks quite complex and unlike any others cited in various posts. I'm reluctant to edit it without being sure of what I'm doing.
My sound output devices are as follows:
di@DiPi:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
  Subdevices: 8/8
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
card 2: vc4hdmi0 [vc4-hdmi-0], device 0: MAI PCM vc4-hdmi-hifi-0 [MAI PCM vc4-hdmi-hifi-0]
  Subdevices: 1/1
card 3: vc4hdmi1 [vc4-hdmi-1], device 0: MAI PCM vc4-hdmi-hifi-0 [MAI PCM vc4-hdmi-hifi-0]
  Subdevices: 1/1
card 4: Device [USB Audio Device], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
forbiddenera
Sat May 01, 2021 3:29 am
Thanks, TL/DR is in bold below.
I am not familiar with MATE to know whitch part of the X stack it was in; openbox/lightdm is perfect for my setup. Getting Chromium running in Kiosk mode is no problem, I didn't need any help setting this up as we were already doing it with Pi4B - was only working towards getting the boot times for running kiosk mode as low as possible.
My main remaining issues:
1. Without initramfs, how am I able to get plymouth running for boot screens? Normally it's triggered there in Canoncial's release, I believe.. Should I just try to trigger it as early as possible in systemd maybe? Does the standard build use bootscreens/plymouth, if so how's it setup? The default installed config isn't working as like I said I believe it's triggered earlier than systemd ..?
2. Can you please update your Chromium build to version 90+? thanks
3. I'd like to be able to strip & rebuild the kernel if you can help, I believe your post mentioned that the sources are pre-installed, not sure if this is still the case for minimal..do you have any config/prep scripts for it with your boot process being a bit different?
Out of curiosity, why is u-boot not needed? canoncial's release uses u-boot and I had to modify it to get rid of any boot delays and prevent it from using the UART. I'm not as immediately familiar with the booting process on arm or why u-boot was used if it wasn't needed. I haven't actually tested but it seems like this minimal install is taking more time to init the kernel than the Canoncial release with u-boot set for no delay; but this is an empirical feeling and also comparing pi4b (canoncial/uboot) vs cm4 (your minimal)
I've gotten the boot time down to 24s from sudo reboot to Chromium ready, 22s from power on to Chromium ready and 12s from kernel init to Chromium ready. This means half of my boot time is spent in the boot loader/prekernel.
So, in seeking the best boot times I'm trying to trim the entire boot process as much as possible. With your image helping quite a bit (simply due to it already being minimal and not having to remove a ton of stuff) I think if I can trim the kernel a bit more, remove any possible boot loader delays (u-boot added 2s by default until it was configured).
Plymouth may not even be useful with such low boot times but a blank screen isn't great UX; would need Plymouth starting super early, I don't mind even stalling for 2-3 sec to show the screen but only if I can lower the pre-kernel/bootloader time as this just shows a blank screen - which makes me wonder more about the boot process here as if compiling in a boot screen to a boot loader is possible, that might be a good option, just like on a standard system you might see GRUB show a graphic until Plymouth takes over.
The first 3 lines or so of kernel text also spill onto the console even with trying to set the console to tty2 in the kernel cmdline. This will be built into a product and I want it to boot cleanly into the app without showing any kernel text or anything. Ideally, ON->BOOT SCREEN->APP, just like an Android tablet or something.
Perhaps providing build instructions for the image would help a lot of people with further customization. Personally I haven't rolled my own distro since like 2008 and a lot has changed since then. I haven't even needed to manually compile a kernel in probably just as long, which, while making me rusty on the deeper side, bodes well for Linux in general. :)
Thanks tons!
forbiddenera
Sun May 09, 2021 11:46 pm
Just bumping this hoping the OP will see my last post.
I'd be even willing to donate some $ to the OP for their time creating this image and answering my post for us all to have some more info and updating Chromium on their package host.
Ideally, some build instructions or insight on building it would be great so that people can replicate what you've done here..while rolling a Linux image shouldn't be too difficult and I'm sure there's lots of info out there about it, there's significantly less available doing so with a Pi/ARM-based system. Others might wish to customize some things without having to dig into all this too, so I'm sure it would be muchly appreciated.
Thanks!
forbiddenera
Mon May 10, 2021 5:50 am
Did you simply use https://github.com/pyavitz/rpi-img-builder or ..?
Only issue I have left is trying to get a boot screen...having a blank screen for 15-20 sec after power on isn't great...
Can't seem to get plymouth to run, I think ubuntu usually runs it in an initfs early, but there's none here.. I suppose it could be started by systemd maybe but I haven't figured that out.. also I read:
PI 4B and the vc-fkms-v3d
This combination has an issue that can not be overcome. The driver needs to reset the framebuffer as it does this the contents are erased there is currently no way to stop this other than disabling the driver. The workaround is to create a service that will reload the image to the display after this reset has happened. This has the effect of having the image on screen for a moment then the screen goes black and the image comes back.
from viewtopic.php?f=66&t=276545
So, if we're using vc-fkms-v3d then plymouth/any other boot screen thing would have to exec after the firmware load I suppose..?
What's the reason for using this? I didn't see it on Canonical's release or rpi's default os?
larryr
Tue Jun 15, 2021 6:14 pm
I am getting an error on the 20.04 image - it has patched fine for months now I get an error and the popup box says /boot is too small.
How do I get around this and fixed - I know I could uninstall bluetooth but what is the correct fix.
Unpacking pi-bluetooth (0.1.15ubuntu2-lobo) over (0.1.15ubuntu0~20.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/pi-bluetooth_0.1.15ubuntu2-lobo_arm64.deb (--unpack):
trying to overwrite '/lib/firmware/brcm/BCM43430A1.hcd', which is also in package linux-firmware-raspi2 4-0ubuntu0~20.04.1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
dpkg-divert: warning: please specify --no-rename explicitly, the default will change to --rename in 1.20.x
dpkg-divert: error: --add needs a single argument
root@rpi01:~# apt update && apt upgrade -y ; apt autoremove -y  ; date
Hit:1 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Get:2 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease [114 kB]
Hit:3 https://linux.teamviewer.com/deb stable InRelease
Get:4 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease [114 kB]
Hit:5 http://loboris.eu/raspi_repo raspi InRelease
Get:6 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe armhf Packages [626 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 Packages [732 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe Translation-en [170 kB]
Fetched 1,757 kB in 2s (867 kB/s)
Reading package lists... Done
Building dependency tree
1 package can be upgraded. Run 'apt list --upgradable' to see it.
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'https://linux.teamviewer.com/deb stable InRelease' doesn't support architecture 'arm64'
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
Use 'apt autoremove' to remove it.
The following packages will be upgraded:
  pi-bluetooth
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/4,687 kB of archives.
After this operation, 16.9 MB of additional disk space will be used.
apt-listchanges: Reading changelogs...
(Reading database ... 213131 files and directories currently installed.)
Preparing to unpack .../pi-bluetooth_0.1.15ubuntu2-lobo_arm64.deb ...
Leaving 'diversion of /lib/firmware/brcm/brcmfmac43455-sdio.bin to /lib/firmware
/brcm/brcmfmac43455-sdio.bin.distrib by pi-bluetooth'
Leaving 'diversion of /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,4-model-
b.txt to /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt.distrib
 by pi-bluetooth'
Use --help for help about diverting files.
dpkg: error while cleaning up:
 new pi-bluetooth package post-removal script subprocess returned error exit sta
tus 2
E: Sub-process /usr/bin/dpkg returned an error code (1)
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/5,548 B of archives.
After this operation, 0 B of additional disk space will be used.
Tue 15 Jun 2021 01:02:35 PM CDT
loboris
Fri Jun 18, 2021 2:55 pm
Try to find the file /var/lib/dpkg/info/linux-firmware-raspi2.postrm.
If it exists, remove it (delete or move it to some other directory).
This must be done as root user (you can use sudo).
Then remove linux-firmware-raspi2 package:
sudo apt remove --purge linux-firmware-raspi2
You can also remove the pi-bluetooth package an install it again.
You can then list all diversions made by linux-firmware-raspi2 with dpkg-divert and remove them manually.
thatchunkylad198966
Fri Jun 18, 2021 3:13 pm
Seems loboris ignored me and you. oh, life is good. :lol:
[NEW] Ubuntu - CM4/RPi4B custom image(s)! XFCE4, LXQt, i3-WM, WireGuard, Samba, Kodi, Latest MESA graphics drivers!
https://www.raspberrypi.org/forums/viewtopic.php?f=131&t=314419
larryr
Sat Jun 19, 2021 3:14 am
Still has the issue - what did I fail to do?
root@rpi02:~# dpkg-divert --list linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,4-model-b.txt to /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,4-model-b.txt.distrib by linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43436-sdio.txt to /lib/firmware/brcm/brcmfmac43436-sdio.txt.distrib by linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43456-sdio.clm_blob to /lib/firmware/brcm/brcmfmac43456-sdio.clm_blob.distrib by linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43436-sdio.clm_blob to /lib/firmware/brcm/brcmfmac43436-sdio.clm_blob.distrib by linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43436-sdio.bin to /lib/firmware/brcm/brcmfmac43436-sdio.bin.distrib by linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,4-compute-module.txt to /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,4-compute-module.txt.distrib by linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43455-sdio.clm_blob to /lib/firmware/brcm/brcmfmac43455-sdio.clm_blob.distrib by linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,400.txt to /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,400.txt.distrib by linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43456-sdio.bin to /lib/firmware/brcm/brcmfmac43456-sdio.bin.distrib by linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43430-sdio.clm_blob to /lib/firmware/brcm/brcmfmac43430-sdio.clm_blob.distrib by linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,4-compute-module.txt to /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,4-compute-module.txt.distrib by linux-firmware-raspi2
diversion of /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,400.txt to /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,400.txt.distrib by linux-firmware-raspi2
root@rpi02:~# cat log
root@rpi02:~# cat log | awk '{print $3}' | sort | uniq
root@rpi02:~# cat log | awk '{print $3}' | sort | uniq > log1
root@rpi02:~# for x in `cat log1`
> do
> dpkg-divert --remove $x
> done
Removing 'diversion of /lib/firmware/brcm/brcmfmac43430-sdio.clm_blob to /lib/firmware/brcm/brcmfmac43430-sdio.clm_blob.distrib by linux-firmware-raspi2'
Removing 'diversion of /lib/firmware/brcm/brcmfmac43436-sdio.bin to /lib/firmware/brcm/brcmfmac43436-sdio.bin.distrib by linux-firmware-raspi2'
Removing 'diversion of /lib/firmware/brcm/brcmfmac43436-sdio.clm_blob to /lib/firmware/brcm/brcmfmac43436-sdio.clm_blob.distrib by linux-firmware-raspi2'
Removing 'diversion of /lib/firmware/brcm/brcmfmac43436-sdio.txt to /lib/firmware/brcm/brcmfmac43436-sdio.txt.distrib by linux-firmware-raspi2'
Removing 'diversion of /lib/firmware/brcm/brcmfmac43455-sdio.clm_blob to /lib/firmware/brcm/brcmfmac43455-sdio.clm_blob.distrib by linux-firmware-raspi2'
Removing 'diversion of /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,400.txt to /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,400.txt.distrib by linux-firmware-raspi2'
Removing 'diversion of /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,4-compute-module.txt to /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,4-compute-module.txt.distrib by linux-firmware-raspi2'
Removing 'diversion of /lib/firmware/brcm/brcmfmac43456-sdio.bin to /lib/firmware/brcm/brcmfmac43456-sdio.bin.distrib by linux-firmware-raspi2'
Removing 'diversion of /lib/firmware/brcm/brcmfmac43456-sdio.clm_blob to /lib/firmware/brcm/brcmfmac43456-sdio.clm_blob.distrib by linux-firmware-raspi2'
Removing 'diversion of /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,400.txt to /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,400.txt.distrib by linux-firmware-raspi2'
Removing 'diversion of /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,4-compute-module.txt to /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,4-compute-module.txt.distrib by linux-firmware-raspi2'
Removing 'diversion of /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,4-model-b.txt to /lib/firmware/brcm/brcmfmac43456-sdio.raspberrypi,4-model-b.txt.distrib by linux-firmware-raspi2'
root@rpi02:~# apt update && apt upgrade -y ; apt autoremove -y ; date
Hit:2 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
  pi-bluetooth
(Reading database ... 213119 files and directories currently installed.)
Leaving 'diversion of /lib/firmware/brcm/brcmfmac43455-sdio.bin to /lib/firmware/brcm/brcmfmac43455-sdio.bin.distrib by pi-bluetooth'
Leaving 'diversion of /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt to /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.
txt.distrib by pi-bluetooth'
 new pi-bluetooth package post-removal script subprocess returned error exit status 2
Fri 18 Jun 2021 10:08:17 PM CDT
root@rpi02:~#
loboris
Sat Jun 19, 2021 8:50 am
Have you removed linux-firmware-raspi2 package?
larryr
Sat Jun 19, 2021 1:00 pm
Yes - renamed it - move to /tmp
Unable to install or uninstall pi-bluetooth
root@rpi02:/var/lib/dpkg/info# dpkg-divert --list linux-firmware-raspi2
root@rpi02:/var/lib/dpkg/info# apt update && apt upgrade -y ; apt autoremove -y ; date
Get:6 http://ports.ubuntu.com/ubuntu-ports focal-updates/main armhf Packages [736 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 Packages [788 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 Packages [735 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe armhf Packages [628 kB]
Fetched 3,115 kB in 2s (1,386 kB/s)
  pi-bluetooth
 by pi-bluetooth'
tus 2
Sat 19 Jun 2021 07:52:20 AM CDT
root@rpi02:/var/lib/dpkg/info# apt remove pi-bluetooth
The following packages will be REMOVED:
  pi-bluetooth
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 29.7 kB disk space will be freed.
Do you want to continue? [Y/n]
dpkg: error processing package pi-bluetooth (--remove):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting a removal
dpkg: too many errors, stopping
 pi-bluetooth
Processing was halted because there were too many errors.
root@rpi02:/var/lib/dpkg/info# ls linux-firm*
linux-firmware-raspi2.list     linux-firmware-raspi2.preinst
linux-firmware-raspi2.md5sums  linux-firmware-raspi2.triggers
root@rpi02:/var/lib/dpkg/info# apt install pi-bluetooth
  pi-bluetooth
Reading changelogs... Done
Leaving 'diversion of /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt to /lib/firmware/brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt.distrib by pi-bluetooth'
tus 2
loboris
Sat Jun 19, 2021 1:46 pm
Did you removed linux-firmware-raspi2 package with
larryr
Sat Jun 19, 2021 6:51 pm
from the fc -l listing 380 was the remove --purge
If you want I have teamviewer installed and can let you see for yourself.
379	 mv linux-firmware-raspi2.postrm /tmp/linux-firmware-raspi2.postrm
380	 apt remove --purge linux-firmware-raspi2
381	 dpkg-divert --list linux-firmware-raspi2
thatchunkylad198966
Tue Jun 22, 2021 10:39 am
Most likely, yes he uses that.
loboris
Tue Jun 22, 2021 11:00 am
You can try to remove pi-bluetooth.postrm the same way you removed linux-firmware-raspi2.postrm and then remove the pi-bluetooth package.
New versions of pi_bluetooth do not use any diversions.
loboris
Tue Jun 22, 2021 11:07 am
I do not use that. I use my own build script(s) for building the image and my own script(s) for building the linux kernel and some RPi related ubuntu packages.
I haven't tested the rpi-img-builder, so it may be better than my own, I can tell nothing about it.
If anyone is interested, I can provide my scripts on request.
thatchunkylad198966
Tue Jun 22, 2021 11:59 am
Someone has already asked if you could share how you do it, you didn't reply.
larryr
Tue Jun 22, 2021 1:02 pm
Still has the problem.
This is what I did
root@rpi02:~# cd /var/lib/dpkg/info
root@rpi02:/var/lib/dpkg/info# ll pi*
-rw-r--r-- 1 root root  364 May 19 16:13 pi-bluetooth.list
-rw-r--r-- 1 root root  458 Apr 27 18:27 pi-bluetooth.md5sums
-rwxr-xr-x 1 root root 2493 Apr 27 18:27 pi-bluetooth.postinst
-rwxr-xr-x 1 root root 1275 Apr 27 18:27 pi-bluetooth.postrm
-rwxr-xr-x 1 root root  439 Apr 27 18:27 pi-bluetooth.prerm
-rw-r--r-- 1 root root  390 Jun  3  2020 pinentry-curses.list
-rw-r--r-- 1 root root  512 Mar 22  2020 pinentry-curses.md5sums
-rwxr-xr-x 1 root root  256 Mar 22  2020 pinentry-curses.postinst
-rwxr-xr-x 1 root root  124 Mar 22  2020 pinentry-curses.prerm
-rw-r--r-- 1 root root  345 Jun 30  2020 pinentry-gnome3.list
-rw-r--r-- 1 root root  434 Mar 22  2020 pinentry-gnome3.md5sums
-rwxr-xr-x 1 root root  473 Mar 22  2020 pinentry-gnome3.postinst
-rwxr-xr-x 1 root root  200 Mar 22  2020 pinentry-gnome3.prerm
root@rpi02:/var/lib/dpkg/info# mv pi-bluetooth.postrm /tmp
root@rpi02:/var/lib/dpkg/info# apt remove --purge pi-bluetooth.postrm
E: Unable to locate package pi-bluetooth.postrm
E: Couldn't find any package by glob 'pi-bluetooth.postrm'
root@rpi02:/var/lib/dpkg/info# dpkg-divert --list pi-bluetooth.postrm
  pi-bluetooth
 pi-bluetooth
root@rpi02:/var/lib/dpkg/info# apt reinstall pi-bluetooth
  pi-bluetooth
 by pi-bluetooth'
tus 2
  pi-bluetooth
 pi-bluetooth
root@rpi02:/var/lib/dpkg/info# pkg-divert --list pi-bluetooth.postrm
-bash: pkg-divert: command not found
  pi-bluetooth
 pi-bluetooth
  pi-bluetooth
 by pi-bluetooth'
tus 2
  pi-bluetooth
 pi-bluetooth
larryr
Tue Jun 22, 2021 1:21 pm
Got it fixed
you have to remove all the /var/lib/dpkg/info/linux-firmware-raspi2* files - as long as lists is there it see it installed.
root@rpi02:/var/lib/dpkg/info# rm linux-firmware-raspi2*
root@rpi02:/var/lib/dpkg/info# ll  linux-firmware-raspi2*
ls: cannot access 'linux-firmware-raspi2*': No such file or directory
  pi-bluetooth
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
dpkg: warning: files list file for package 'linux-firmware-raspi2' missing; assu
ming package has no files currently installed
(Reading database ... 212566 files and directories currently installed.)
Preparing to unpack .../pi-bluetooth_9.1.15ubuntu2-lobo_arm64.deb ...
Unpacking pi-bluetooth (9.1.15ubuntu2-lobo) ...
Setting up pi-bluetooth (9.1.15
thatchunkylad198966
Tue Jun 22, 2021 1:32 pm
If you could share your scripts, that would be great!
Cheers!
forbiddenera
Sun Jul 25, 2021 9:00 am
Yeah, would be great, I also want to get this running on a 3b and it doesn't want to go
Return to “Ubuntu”
