geffers
USB WFi Driver Installation
Wed Apr 21, 2021 10:44 am
Reading recently about apparent good support for Linux from TP-Link I purchased an Archer AC600 adapter.
Unfortunately not recognised by any Ubuntu, OpernWRT or Raspberry Pi device.
Strangely followed advice on a Mint forum link and drivers installed fine on Ubuntu 18:04 and Mate 20:04 (On an old Atom 1 32 bit device) but failed to install on an Acer Atom running the R-Pi OS for PC, I get the following error message;
sudo make dkms_install
mkdir -p /usr/src/8812au-5.6.4.2_35491.20191025
cp -r * /usr/src/8812au-5.6.4.2_35491.20191025
dkms add -m 8812au -v 5.6.4.2_35491.20191025
Creating symlink /var/lib/dkms/8812au/5.6.4.2_35491.20191025/source ->
DKMS: add completed.
dkms build -m 8812au -v 5.6.4.2_35491.20191025
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
'make' -j2 KVER=4.9.0-15-686-pae KSRC=/lib/modules/4.9.0-15-686-pae/build..............................(bad exit status: 2)
Error! Bad return status for module build on kernel: 4.9.0-15-686-pae (i686)
Consult /var/lib/dkms/8812au/5.6.4.2_35491.20191025/build/make.log for more information.
Makefile:2301: recipe for target 'dkms_install' failed
make: *** [dkms_install] Error 10
Any suggestions appreciated.
Geoff
Re: USB WFi Driver Installation
Wed Apr 21, 2021 10:56 am
Unhelpful and removed ;)
Last edited by fruitoftheloom on Sun Apr 25, 2021 2:02 am, edited 3 times in total.
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
geffers
Wed Apr 21, 2021 9:51 pm
Geoff
viewtopic.php?f=28&t=62371
Wow, thanks for reply but over 1500 messages in that thread so have little idea where to start.
I'm guessing as Ubuntu is based on Debian, as is R-Pi for PC then somehow it can work so will continue to experiment.
Geffers
Wed Apr 21, 2021 10:08 pm
And simple instructions halfway down the first post on the first page.
sudo wget http://downloads.fars-robotics.net/wifi-drivers/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
sudo install-wifi
Thu Apr 22, 2021 4:05 am
geffers
Thu Apr 22, 2021 9:11 pm
Geffers
MrEngman compile on Raspberry Pi OS because that is the supported Operating System, it will likely not work in Ubuntu..
Therefore you should have posted in the Ubuntu section to avoid us helpers wasting our time, have requested Mods to move post.
Fortunately no-one has wasted any time as my question related to The Raspberry Pi Desktop running on an Acer Atom. The reference to Ubuntu merely pointed out the driver problem was overcome with that system.
Geffers
Fri Apr 23, 2021 4:54 pm
It's DebIan, so start here: https://wiki.debian.org/WiFi
geffers
Sat Apr 24, 2021 8:11 am
Good idea, I do have a Debian system on an external disk so may well try it on that.
I have a Pi 3B on which I have installed open-wrt - works great as a router but onboard WiFi has a limited range, hence the tp-link device.
So many Pi projects to keep one busy :ugeek:
Geffers
geffers
Sat Apr 24, 2021 8:55 am
sudo wget http://downloads.fars-robotics.net/wifi ... stall-wifi -O /usr/bin/install-wifi
sudo install-wifi
Thanks Dougie,
Initial intention was to use this device with open-wrt on a Pi but that may be a major stumbling block too.
Pondering what to use the device for, I do have a few Pi 1s (were they ever called Pi Ones) but they are happily connected to ethernet.
Geffers
Return to “Raspberry Pi Desktop for PC and Mac”
