Pimaxin
[ubuntu] Getting CPU tempature on Ubuntu
Thu Sep 19, 2019 1:32 am
I have Ubuntu installed on my Raspberry Pi 4 and was wondering if there's a way to run vcgencmd or get the CPU tempature?
mallets
Re: Getting CPU tempature on Ubuntu
Thu Sep 19, 2019 4:02 am
cat /sys/class/thermal/thermal_zone0/temp
works for me. I'm still searching for the CPU freq value though.
Pimaxin
Thu Sep 19, 2019 9:17 am
What’s 38459 supposed to mean?
Thu Sep 19, 2019 9:31 am
It's a prime number!
Working in the Application's Team.
Thu Sep 19, 2019 9:42 am
The successor to 38458.
Re: [ubuntu] Getting CPU tempature on Ubuntu
Thu Sep 19, 2019 10:30 am
A clue for American viewers. It works in Centigrade.
rpdom
Thu Sep 19, 2019 10:32 am
If that is the value returned from that command for you, it means your CPU temperature is currently 38.459°C
Unreadable squiggle
Thu Sep 19, 2019 10:34 am
Take the prime number divide by 1000, multiply by 1.8 and add 32. You'l then get the temperature on the scale of that really bad physicist Mr. F.
I'm surprised nobody has suggested getting the userland (https://GitHub.com/raspberrypi/userland) pieces installed on Ubuntu. To add some of the missing pieces.
Thu Sep 19, 2019 11:56 am
Now, now, you can't go round calling members of the FRS "bad physisists".
Physics did not exist back then. Guys like Mr F. invented it for us.
Rock bands and authors have been celebrating his name for ages: https://en.wikipedia.org/wiki/Fahrenhei ... biguation)
BluPI2
Sun Sep 22, 2019 5:40 am
There is a nice way to add this to the taskbar in Ubuntu
Steps
1. Right-click taskbar and click +add to panel
2. Scroll down and Highlight Command(Shows the output of a command), Click Add
3. Right-click the newly added widget, click preferences, and set interval seconds to 5
and max character width to 2. Copy and Paste this command into the Command Box
You now get the temperature displayed in your taskbar which updates every 5 seconds displayed in Celsius.
Even in the United States we still use Centigrade to measure the temperature of a CPU.
Proud Owner of a Raspberry Pi 3B and 3B+ running Ubuntu Mate
aduen
Tue May 05, 2020 11:50 am
For the bash aficionados:
#!/bin/bash
temp=$(</sys/class/thermal/thermal_zone0/temp)
temp_f=`echo "$temp/1000" | bc -l`
printf "CPU Temp: %.3f°C\n"  $temp_f
>> CPU Temp: 40.407°C
aturfer
Sat Jun 06, 2020 11:12 pm
For those who feel like compiling something, create file temp.c with the following:
#include <stdio.h>
int main(int argc, char *argv[])
   FILE *fp;
   int temp = 0;
   fp = fopen("/sys/class/thermal/thermal_zone0/temp", "r");
   fscanf(fp, "%d", &temp);
   printf(">> CPU Temp: %.2f°C\n", temp / 1000.0);
   fclose(fp);
   return 0;
Compile with:
$ gcc temp.c -o temp
Then copy to directory in your path:
$ sudo mv ./temp /usr/local/bin/
Run from anywhere:
aturfer@pi4:~$ temp
>> CPU Temp: 42.35°C
aturfer
Sat Jun 06, 2020 11:44 pm
Current CPU frequency:
echo ">> CPU Freq:" $(($(cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq)/1000))MHz
To get min/max CPU frequency range:
lscpu | grep -i mhz
saikiran91
Sat Jul 04, 2020 1:34 pm
#include <stdio.h>
   FILE *fp;
   int temp = 0;
   fclose(fp);
   return 0;
Compile with:
Run from anywhere:
aturfer@pi4:~$ temp
>> CPU Temp: 42.35°C
Simple and sexy. One more request how can we get a continuous updates.
insanish1
Mon Aug 10, 2020 3:28 pm
#include <stdio.h>
   FILE *fp;
   int temp = 0;
   fclose(fp);
   return 0;
Compile with:
Run from anywhere:
aturfer@pi4:~$ temp
>> CPU Temp: 42.35°C
root@brobdinang:~# watch tempchk
wirpool
Sat Aug 22, 2020 8:04 am
Hi everyone, you can check the temperature with a command
install it with
sudo apt lm-sensors
than type the following for temperature
sensors
add -f as below if you want the temp in farenheit
sensors -f
obviusly you can find all info typing
sensors --help
hope it will be usefull :D :D
SnowFuhrer
Sat Dec 19, 2020 8:28 am
Just been learning bash tonight xD. Here is a modified script which has live update.
#!/bin/bash
while true
do
 printf  "CPU Temp: %.3f C\r\e\e[?25l"  $temp_f
 sleep 1
done
couling
Wed Mar 10, 2021 3:52 pm
So the original question was about the vcgencmd command. I'm a little surprised that comments haven't pointed out that it's available in the libraspberrypi-bin package.
Assuming you have "universe" in your /etc/apt/sources.list you can just:
sudo apt-get install libraspberrypi-bin
There's a note here to suggest that "linux methods" are inaccurate:
Due to the architecture of the SoCs used on the Raspberry Pi range, and the use of the upstream temperature monitoring code in the Raspberry Pi OS distribution, Linux-based temperature measurements can be inaccurate.
kerry_s
Wed Mar 10, 2021 4:02 pm
sudo apt install gnome-shell-extension-system-monitor
then reload:
alt+f2 r
WB4WTN
Tue Apr 13, 2021 9:37 pm
I just use vcgencmd measure_temp.
kerry_s
Tue Apr 13, 2021 10:14 pm
i do to, but ubuntu does not have that.
fprietog
Wed Apr 14, 2021 11:23 am
Command vcgencmd is available for Ubuntu in the package libraspberrypi-bin.
Anyway, my favorite ways to control temperature are psensor and indicator-sensors, both graphical.
Return to “Ubuntu”
