Mister Fab
Artifact blinking on the screen
Thu Aug 20, 2020 12:43 pm
Hi all,
I have a problem with a fresh new install of Ubuntu Mate 20.04
Since the machine start, the screen is blinking with artifacts
I don't have this problem with RPi OS with the same SDcard, the display works perfectly.
Also in the screen configuration menu, I can see "Unknown monitor" and I can't change the parameters.
Has someone got an idea on how to fix this?
larryr
Re: Artifact blinking on the screen
Thu Aug 20, 2020 2:57 pm
Use this Ubuntu image as it works for everything unlike Ubuntu's
I tried to get things working with the pure Ubuntu but things kept failing to work as expected
Loboris has fixed all the problems in the Ubuntu image. Get it here:
viewtopic.php?f=131&t=279323
Mister Fab
Fri Aug 21, 2020 6:16 am
Thank you for your answer.
I use a raspberry pi 3 B+, does this image work on it?
Return to “Ubuntu”
