gordonfreemanjr
Can’t install Ubuntu on RPI 4
Wed Nov 06, 2019 2:45 pm
Ok, I’m officially unable to install Ubuntu on my Raspberry Pi 4. So far I tried 3 ways, all of them with a freshly FAT32 formatted SD card:
18.10 through Berryboot. I run Berryboot fine, download the Ubuntu Server image, reboot and the process is stuck within seconds on: cloud-init v. 19.1-1 etc, and it just won’t carry on.
Official 19.10 32-bit Server image. I flash the image on the card, boot up, the process runs for about 5 mins, then freezes on:
[done] started daily apt upgrade and clean activities
and just won’t carry on.
Official 19.10 64-bit Server image. Exactly as above.
The RPI4 is the 4GB version. Any help appreciated, I have nothing. The Ethernet is plugged in, the network is working.
Re: Can’t install Ubuntu on RPI 4
Wed Nov 06, 2019 3:00 pm
Forget NoobS, BerryBoot and PiNN, just use the Canonical download as per:
https://ubuntu.com/download/iot/raspberry-pi
https://ubuntu.com/blog/roadmap-for-off ... berry-pi-4
Last edited by fruitoftheloom on Wed Nov 06, 2019 3:03 pm, edited 1 time in total.
Retired disgracefully.....
B.Goode
"Officially unable" seems a correct summary -
The Raspberry Pi 4 model B comes with different choices of RAM: 1GB, 2GB and 4GB. However, our official support for this board is currently limited to the 1GB and 2GB versions.
Ref: https://ubuntu.com/blog/roadmap-for-off ... berry-pi-4
gordonfreemanjr
Wed Nov 06, 2019 3:16 pm
:o How did I miss this?
Thanks.
Anyway, the sole reason of my attempts to install Ubuntu on RPI4 are to run Steam and GOG Galaxy clients. Can you recommend any other available OS capable of doing that?
phase
Thu Nov 07, 2019 8:21 am
if you have issues with the usb ports you have to limit the ram to 3072Mb...i still found issues with the ports even after i set this parameter..seems like a power issue..not shure... but they will fix it..
total_mem=3072
if you want to utilize whats not being used ...install zram as swap mem
apt install zram-config
reboot.
gordonfreemanjr
Thu Nov 07, 2019 9:11 am
Thank you, but that is not the case. Any install just won’t complete, freezing at the same moment. So I didn’t even get to the USB thing, heh.
Thu Nov 07, 2019 9:47 am
total_mem=3072
reboot.
Not a power problem - Canonical need to use the bounce buffer code present in Raspbian as the PCIe peripheral can only access the first 3GB of RAM.
This is why third party OS's are generally not as good as Raspbian - they do not know enough about the HW to do a thorough job.
phase
Thu Nov 07, 2019 3:35 pm
ok thank`s for that info...it will most likely become handy when i tell others...on other forum`s i am a member of...thx
phase
Thu Nov 07, 2019 3:41 pm
@gordon you have to edit the config.txt file prior to inserting the media,,,,hence edit it first then insert and power up the rpi-4...
gordonfreemanjr
Thu Nov 07, 2019 4:53 pm
phase wrote: @gordon you have to edit the config.txt file prior to inserting the media,,,,hence edit it first then insert and power up the rpi-4...
@phase How so?
Thu Nov 07, 2019 5:25 pm
@phase How so?
Why not read the link which was posted above ??
gordonfreemanjr
Thu Nov 07, 2019 5:39 pm
This I know. As I’ve written already - why not read? - I never got there. The installation halts way earlier.
Thu Nov 07, 2019 6:01 pm
You should be able to edit that file on the machine you used to create the SD Card !
Which was written above by phase....
topguy
Thu Nov 07, 2019 10:29 pm
Can you point me to a link where either of them ( Valve / GOG ) confirm that they have linux clients for ARM computers ?
phase
Fri Nov 08, 2019 12:05 am
download the 64 bit version 19.10 from this page...
you need a 16Gb sd-card minimum....use etcher to flash the image...
once it has flashed ..eject the sd-card reader ..leave the sd-card in the reader...
re insert the sd-card reader with the flashed sd-card in it back into your computer
open the file manager of your choice..you may need admin privileges to edit the file..
it is in the boot partition of the file system and it is an approx 130 odd Mb partition...if your using a windows machine ..you should find it easy....
really i only edited the
usercfg.txt
file ....
..if the files there are in a list ....the file at hand will be around the bottom of the list of files....
open the file and copy paste this code into it...
total_mem=3072
.... this line sets the maximum ram usage....
dtparam=audio=on
.........this line enables the hdmi audio..so
now save the file ...
eject the sd-card reader..remove the sd card..
and insert it into the rpi-4...
connect mouse k-b video Ethernet etc ..you may have a monitor issue so make shore it`s at least native 720p..check cables for known working good ones...
power up the rpi-4..and wait for about 2 or so mins...you should have text running down the screen
it will eventually give you a login prompt...it might roll some more code at this point..just wait till it stops..hit enter a few times..
you should now have the login prompt..go ahead and do the login as i wrote in the next line below...
user and password are both
 Ubuntu
...it should now login ...
it will then ask you to give it you own new password...
once that is done enter this code
sudo su
..hit enter.. that will give you a
 root user
command line prompt
code this...
apt update && apt full-upgrade && apt dist-upgrade
..... hit enter...this will do the upgrade procedure...
answer yes to the prompts so it can do it1s install...once it is done
reboot the rpi-4...
and once again login with your password..and the user name is still Ubuntu ...once your logged in
code this
sudo su
..now you are root user...
once that has done you can now install a desktop..there are a few to choose from ..use google it will help you find other desktop installs...
i chose to .install mate desktop...
apt install ubuntu-mate-desktop
follow the prompts...it has to download about 1400 files so grab a bag of chips sit back and wait for it to finish....you will get a prompt to choose a display manager...i choose ...lightdm...hit enter.. it will continue ...
once it has stopped back at the command prompt...
reboot it,,,,
it should boot up with the mate desktop login screen greeter,,
there is a round dot in the login box click on it and choose the mate option...
enter your password and it will login to the desktop...
you will most likely have to install ...
apt install pavucontrol
so you can setup the hdmi output audio via the mate gui once the desktop is installed
i think that the ram size limit is almost fixed so after running the updates you may find you can omit the ram size lie out of the usercfg,txt file..just put an "#" mark in the front of it`s line with a space after the hash..
you may want to install virtual memory...
apt install zram-control..this requires a reboot to apply it into the system....
i would like to add that i played around in the "software & updates" in the gui under the administration menu and selected everything that was not selected
i have this outcome::
@ubuntu:/home/ubuntu# uname -a
Linux ubuntu 5.3.0-1011-raspi2 #12-Ubuntu SMP Fri Nov 1 09:07:06 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux
[email protected]:/home/ubuntu#
there is a few bugg`s in it still and this is a server image ..there are still packages that are still missing like i2c-tools ....etc..etc
the rest is up to you...
all the best phase....
i think that is the basics 4 you or whoever reads this post....been a long day....
BRX7
Fri Nov 08, 2019 3:49 pm
Can the img be extracted and copied straight to empty project partitions (boot root) ?
my sdcard is created with pinn with empty project spaces
update I have extracted it, now need to know how to make it work with pinn,
cmmdline.txt is missing so i did ln -s to btcmd.txt , i have the os json on the boot paratition
anything else i should look to adjust?
geev03
Fri Nov 08, 2019 6:53 pm
Thank you, it was easy to get it all working (remote, "headless & arm less" ) in about an hour.
PeterO
Fri Nov 08, 2019 7:10 pm
From https://ubuntu.com/blog/roadmap-for-off ... berry-pi-4
Kernel fixes have been identified by Canonical engineers. We are currently testing these fixes extensively. We will push updates within weeks, following successful test completion.
That's a bit rich when you've already published the fix don't you think ?
PeerO
geev03
Fri Nov 08, 2019 7:47 pm
After the reboot Kernel changed to 'Kernel: 5.3.0-1008-raspi2' , solving several problems.
XRDP works 'out of the box' :D .
Last login: Fri Nov  8 17:43:28 2019 from 192.168.1.75
[email protected]:~$ neofetch
            .-/+oossssoo+/-.               [email protected]
        `:+ssssssssssssssssss+:`           -------------
      -+ssssssssssssssssssyyssss+-         OS: Ubuntu 19.10 aarch64
    .ossssssssssssssssssdMMMNysssso.       Host: Raspberry Pi 4 Model B Rev 1.1
   /ssssssssssshdmmNNmmyNMMMMhssssss/      Kernel: 5.3.0-1008-raspi2
  +ssssssssshmydMMMMMMMNddddyssssssss+     Uptime: 48 mins
 /sssssssshNMMMyhhyyyyhmNMMMNhssssssss/    Packages: 2104 (dpkg), 3 (snap)
.ssssssssdMMMNhsssssssssshNMMMdssssssss.   Shell: bash 5.0.3
+sssshhhyNMMNyssssssssssssyNMMMysssssss+   Terminal: /dev/pts/1
ossyNMMMNyMMhsssssssssssssshmmmhssssssso   CPU: (4) @ 1.500GHz
ossyNMMMNyMMhsssssssssssssshmmmhssssssso   Memory: 1269MiB / 3793MiB
 /sssssssshNMMMyhhyyyyhdNMMMNhssssssss/
  +sssssssssdmydMMMMMMMMddddyssssssss+
   /ssssssssssshdmNNNNmyNMMMMhssssss/
      -+sssssssssssssssssyyyssss+-
            .-/+oossssoo+/-.
Fri Nov 08, 2019 9:33 pm
PeerO
It's a bit richer to do all the testing after the product has been released!
BRX7
Sat Nov 09, 2019 10:18 am
hello @procount if your browsing, any tips to get this image to boot with pinn with cmdine.txt?
or anyone else even
Matha
Sun Nov 10, 2019 3:34 pm
Agree totally with the sentiments by RPi engineer(s) here. Two peeves:
  • Canonical never tested their image with the 4GB model
  • The image naming convention, i.e. without release date or minor version number, is a bit lame. Are we supposed to review the checksum to understand that the original release has now been modified.
Sorry folks, just venting here because posting at UbuntuOne did not generate a single response. BTW, Hui Wang patched the issue in late Aug/early Sep with no regression test failures reported. And yet we still do not have a new ubuntu-server image. Perhaps, Ben and Mark could exchange some notes on agreeing with the nomenclature standards established by the Foundation for public image downloads.
Kind regards.
fatemamiller
Thu Nov 14, 2019 3:55 pm
I think none of the forum members knows about it.
Return to “Ubuntu”
