webrtchacks
visionkit: bonnet boot failed -113
Sat Dec 30, 2017 4:16 pm
I purchased the Vision Kit yesterday on a new Pi Zero W, but I cannot get to to work. It seems the Myriad chip is not loading:
journalctl shows the following on my first boot after loading the image:
pi@raspberrypi:~ $ journalctl | grep visionbonnet
Dec 18 10:36:29 raspberrypi kernel: googlevisionbonnet spi0.0: Initializing
Dec 18 10:36:29 raspberrypi kernel: googlevisionbonnet spi0.0: Resetting myriad on probe
Dec 18 10:36:37 raspberrypi kernel: googlevisionbonnet spi0.0: Writing myriad firmware
Dec 18 10:36:41 raspberrypi kernel: googlevisionbonnet spi0.0: Myriad booting
Dec 18 10:36:46 raspberrypi kernel: googlevisionbonnet spi0.0: Slave not ready after 5000 ms
Dec 18 10:36:46 raspberrypi kernel: googlevisionbonnet spi0.0: Myriad did not boot in a timely fashion
Dec 18 10:36:46 raspberrypi kernel: googlevisionbonnet spi0.0: Inital bonnet boot failed: -113
Dec 18 10:36:46 raspberrypi kernel: googlevisionbonnet: probe of spi0.0 failed with error -113
I am able to get the camera to work if I connect it directly to the Pi Zero W and ~/AIY-projects-python/src/example/buzzer_demo.py works fine too.
I also tried enabling the SPI through raspi-config and /boot/config.txt with no success.
What does error -113 mean? Are there any diagnostics I can do?
sheridat
Re: visionkit: bonnet boot failed -113
Sat Dec 30, 2017 8:21 pm
Your the first person with a Vision Kit to post in this forum.
Whilst someone might come along with help - can I suggest that if you followed this guidance https://aiyprojects.withgoogle.com/vision/ you raise the issue with google by posting a new issue at the following url https://github.com/google/aiyprojects-raspbian/issues
webrtchacks
Sat Dec 30, 2017 11:01 pm
Thanks. I posted the issue here for reference: https://github.com/google/aiyprojects-r ... issues/217
sheridat
Sat Dec 30, 2017 11:28 pm
Hi, I've just updated your issue.
May be worth un commenting some of the lines in the /boot/config.txt specifically
# dtoverlay=googlevisionbonnet-myriad
# dtoverlay=aiy-io
# dtoverlay=aiy-leds
# dtoverlay=dwc2
Best to un comment them one at a time and reboot
Gizmo1k
Fri Jan 05, 2018 2:23 pm
i have mine working and my /boot/config.txt has the follwoing commented.
# Enable audio (loads snd_bcm2835)
#dtparam=audio=on
# dtoverlay=i2s-mmap
# dtoverlay=googlevoicehat-soundcard
# dtoverlay=aiy-io
also something for you to compare against hope this helps.
Jan 01 11:24:42 raspberrypi kernel: googlevisionbonnet spi0.0: Initializing
Jan 01 11:24:42 raspberrypi kernel: googlevisionbonnet spi0.0: Resetting myriad on probe
Jan 01 11:24:47 raspberrypi kernel: googlevisionbonnet spi0.0: Writing myriad firmware
Jan 01 11:24:52 raspberrypi kernel: googlevisionbonnet spi0.0: Myriad booting
Jan 01 11:24:52 raspberrypi kernel: googlevisionbonnet spi0.0: Myriad ready
Jan 04 22:03:43 raspberrypi kernel: googlevisionbonnet spi0.0: Incoming crc mismatch: slave 23b9a8f8 vs computed bddd3d5b
Jan 04 22:09:25 raspberrypi kernel: googlevisionbonnet spi0.0: Incoming crc mismatch: slave c706fea5 vs computed c9dd7697
sheridat
Fri Jan 05, 2018 5:06 pm
Turned out to be a pin header problem. Now resolved
Return to “AIY Projects”
