kramkroc
Raspberry Pi Certified Educator
Pi with AIY borks after upgrade
Fri Aug 04, 2017 10:23 am
Hi folks,
I've tried to do the following twice now and with the same end result. I've AIY installed on my Pi and I've simply tried to upgrade to latest underlying Raspbian distro:
    sudo apt-get update
    sudo apt-get upgrade
I haven't babysat the install so I'm not sure which package is causing the issue, but when I check on the update, both times I found that the menu etc have disappeared and only the desktop image is present. When I power off and reboot the Pi, it gets through the splash screen/launch, but then the mouse, keyboard etc cannot be used and indicators for bluetooth, wireless etc indicate they are inactive.
Any ideas? I can always try the vanilla Raspbian image instead of the SD card as a next step.
/KramKroc
eoinzy
Re: Pi with AIY borks after upgrade
Mon Aug 07, 2017 9:10 pm
Try upgrade using these instructions:
http://eduncan911.com/stem/embedded/aiy ... -2017.html
bensimmo
Tue Aug 08, 2017 5:47 am
run a
sudo apt-get dist-upgrade
and reboot.
assuming it's the desktop problem you are talking about and not actually the AIY, though is this the AIY image or AIY installed on a normal Raspbian install ?
Return to “AIY Projects”
