winkleink
Speaker is very crackly [solved]
Fri May 05, 2017 9:50 pm
I've done the install and enable the API.
When I press the button to give a command it looks like it's working and that PI is trying to play the audio but it's not working.
I've tried removing and re-tightening the screen terminal block.
Any advise appreciated.
This is a link to a short YouTube video.
https://www.youtube.com/watch?v=QyQ_T85MAEs
Solution:
I removed the speaker and put the wires back in again and rescrewed everything tighter making sure not to screw the plastic and now working great.
Video proof.
https://youtu.be/vp8TGarSgDs
Twitter:Winkleink
Google+: Winkleink
scotty101
Re: Speaker is very crackly
Fri May 05, 2017 10:18 pm
Have you run the 'test audio' or something like that which is on the desktop?
Bodestone
Re: Speaker is very crackly [solved]
Sat May 13, 2017 8:12 pm
Marked as solved but no explanation as to steps other than running the test that just ask if you can hear it or not.
B.Goode
Sat May 13, 2017 8:39 pm
Bodestone wrote:Marked as solved but no explanation as to steps other than running the test that just ask if you can hear it or not.
I thought the explanation was here:
Solution:
Bodestone
Mon May 15, 2017 10:07 pm
Sorry, must have missed bits.
Still an issue with when the voice hat responds as opposed to the web interface but not this one.
Return to “AIY Projects”
