AIY Microphone barely working
by JPrograms » Fri May 19, 2017 3:40 pm
I assembled my AIY project kit yesterday according to the included instructions in the magazine (except renamed the json file to assistant.json per online instructions) I downloaded the latest OS image and started it up as the instructions said. I ran the Audio Test from the desktop and the speaker worked great, but the audio recording is very fuzzy and I have to yell to hear my voice. Any ideas on what the problem might be?
by Protorabbit » Fri May 19, 2017 4:02 pm
Same problem here, i think it's a defect
I mailed support-aiyprojects@google.com
An email adres i found on https://aiyprojects.withgoogle.com/voice/
by JPrograms » Fri May 19, 2017 5:51 pm
I emailed them too. Haven;t got a reply yet. If you do get a reply with a way to fix it could you post it here? Thanks
by Protorabbit » Fri May 19, 2017 7:08 pm
of course i will :)
by scraggleDog » Fri May 19, 2017 9:17 pm
I had the same problem to begin with. What fixed it for me, was re-writing the image to the SD card. The first time I did this, using Etcher, it appeared to write the whole image, but failed on the verification part of it. I just ignored that and figured it would probably work. The speaker test was fine, but the recording playback was terrible. When I re-wrote the image, it passed the verification this time and when I ran the speaker test and recording test again, the problem was fixed. It might not work for you, but it fixed the problem for me, so might be worth a try.
by JPrograms » Sat May 20, 2017 10:56 pm
I accidently messed something up with my install, so re installed the OS using Etcher. I had a clean install that time but problem still persisted. At two different times it did start working, but stopped after a while. I found out that it might be some components on the back of the mic that came loose when I tried repositioning the tape they holds it on. I may try some testing with that and will let you know what I find ;)
by JPrograms » Sun May 21, 2017 10:06 pm
Now I'm thinking that it may be software. Still not sure though :(
by S0litaire » Sun May 21, 2017 10:42 pm
Did you get your microphones to sit flush against the inside of the box?
My first try the pickup from them was terrible, then I noticed that the pins from the central connector stopped them sitting flush up against the holes.
I made a small slit in the cardboard to accommodate the pins and got then as close as possible to the holes.
The sound pickup was greatly improved. worth a shot if using the box.
Laters
Bill "Solitaire" C
Anáil nathrach, ortha bhas betha, do cheol déanta
by JPrograms » Mon May 22, 2017 5:02 pm
I'm currently testing without the box and problem still persists.
by JPrograms » Tue May 23, 2017 1:46 am
I did a little testing and here's what I know so far:
The problem is not in the Voice HAT board, for I tried attaching the microphone directly to the raspberry pi via these instructions:
https://learn.adafruit.com/adafruit-i2s-mems-microphone-breakout/raspberry-pi-wiring-and-test
The results were exactly the same.
That leaves either the software or the microphone. I'm not exactly sure but I saw, after Google-ing for answers, that the LRCLK and BCLK pins might be running wrong. Again, not sure on this and I couldn't find much info on it either.
Also as an FYI I have been using the command
arecord | aplay -
for live mic playback/testing (Be careful as it may repeat itself through the speaker)
Hope this helps for further testing.
by JPrograms » Wed May 24, 2017 1:54 am
So after almost an entire week searching Google for answers, here's how I fixed it:
Blow on it.
I don't know why but it works perfect now. I blew pretty hard on the microphones and they work great now. WAY louder than I thought it would be. Very frustrating though that it was a five second fix :lol:
by stephen.george.west » Wed May 24, 2017 1:16 pm
I'm getting this too.
[quote]Blow on it.[/quote]
Oddly, that helped a bit, the first time, but it didn't hold up long. It didn't sound good, but I think the voice recognition might have worked if it stayed. I'm going to try swapping the mic/hat/pi/sdcards with another guy at work who got one too. I'll see what works.
by JPrograms » Wed May 24, 2017 1:47 pm
Yeah, I guess mine was only a temporary fix too. But now I know it is (probably) the microphone that isn't working, not the software.
by sheridat » Wed May 24, 2017 2:12 pm
I had my box apart the other day to solder pins on the hat..
I put it back together and it no longer worked. Looking at the log I was getting an error regarding the microphone. Took it apart put it back together - wiggled the leads and so on - eventually in desperation I re-imaged the SD card and hey presto it worked.
I was convinced it was hardware - and it turned out not to be. I'm frightened to touch the thing now.
by JPrograms » Thu May 25, 2017 1:22 pm
I've tried imaging three times and it's changed nothing do I don't think it's a software problem
by JPrograms » Fri May 26, 2017 1:47 am
Mine has randomly started working now. Not sure why.
by Protorabbit » Thu Jun 01, 2017 5:39 am
Got a response from google 8-)
And they will send me a replacement whoop
Hi Pieter,
So sorry for the delayed response; we are a very small team working on this project!
It sounds like you may have a bad mic board. We would be happy to send you a replacement kit.
We will need your address and phone number to ship you a replacement kit. By giving us your information, you give us permission to share it with our partners to send you a replacement kit. We will use and maintain your information in accordance with our Privacy Policy (https://www.google.com/policies/privacy/?hl=en).
Hope this helps,
by interaktiv » Thu Jun 01, 2017 10:42 am
Make sure the MIC board are flat against the lid and not dropping at an angle inside the box when closing the lid.
I detailed the problem and possible fix here:
https://www.instructables.com/id/Google ... Mic-Board/
by JPrograms » Thu Jul 06, 2017 2:04 am
Hey Protorabbit. Did you happen to get a replacement kit? I sent mine about the weeks ago and haven't got one back yet. Google also stopped emailing about a will also saying they would've thought I would have one by now...
by Protorabbit » Thu Jul 06, 2017 7:31 am
JPrograms wrote:Hey Protorabbit. Did you happen to get a replacement kit? I sent mine about the weeks ago and haven't got one back yet. Google also stopped emailing about a will also saying they would've thought I would have one by now...
Yes i did receive a new kit and every thing is working great now.
I did not send in my defective ? and there was some miscommunication along the way.
Just send another mail i don't think they have a tracking system in place (small teams will make errors)
by sheridat » Thu Jul 06, 2017 8:51 am
Hi When I wrote to them about my microphone being bust it was about 4 weeks before they replied.
