g8gkq
Recent Update Has Changed Framebuffer Parameters - Solved
Wed Jul 22, 2020 9:08 pm
I am using the official foundation touchscreen with an RPi 4 (2GB) and Raspios 32 bit Buster Lite 2020-05-27 and maintain a build on GitHub for an Amateur Television transmitter based on the RPi 4 and a LimeSDR https://github.com/davecrump/portsdown-a27. My initial build worked well, but a recent update (dist-upgrade) appears to have broken 2 things:
I grep dmesg to look for ft5406 to check that the 7 inch display is connected. This device no longer seems to exist. I can get round this.
The big problem is that I write directly to the framebuffer to display on the screen and all the parameters seem to have changed. This is what I do:
int initScreen(void)
  struct fb_var_screeninfo vinfo;
  struct fb_fix_screeninfo finfo;
  fbfd = open("/dev/fb0", O_RDWR);
  if (!fbfd)
    printf("Error: cannot open framebuffer device.\n");
    return(0);
  if (ioctl(fbfd, FBIOGET_FSCREENINFO, &finfo))
    printf("Error reading fixed information.\n");
    return(0);
  if (ioctl(fbfd, FBIOGET_VSCREENINFO, &vinfo))
    printf("Error reading variable information.\n");
    return(0);
  screenXsize=vinfo.xres;
  screenYsize=vinfo.yres;
  screenSize = finfo.smem_len;
  fbp = (char*)mmap(0, screenSize, PROT_READ | PROT_WRITE, MAP_SHARED, fbfd, 0);
  if ((int)fbp == -1)
    return 0;
  else
    return 1;
Then based on this offset (fbp) I write to each pixel:
void setPixel(int x, int y, int R, int G, int B)
  int p;  // Pixel Memory offset
  if ((x < 800) && (y < 480))
    p=(x + screenXsize * y) * 4;
    memset(fbp + p, B, 1);         // Blue
    memset(fbp + p + 1, G, 1);     // Green
    memset(fbp + p + 2, R, 1);     // Red
    memset(fbp + p + 3, 0x80, 1);  // A
  else
    printf("Error: Trying to write pixel outside screen bounds.\n");
Is there some new documentation of the structure of the framebuffer?
Dave
Re: Recent Update Has Changed Framebuffer Parameters - To What?
Wed Jul 22, 2020 10:34 pm
I am not sure how the FKMS emulated frame buffer works with that sort of access. But presumably you have always used FKMS, so I am not sure might have changed. There have been major upgrades to a large parts of the graphics stack on the move to 5.4, could be anywhere...
g8gkq
Wed Jul 22, 2020 10:50 pm
Thanks. Looks like I may have to use trial and error then.
I’ve only used FKMS on the RPi 4 because It does not support OpenVG, which I still use in the RPi 3 builds.
Dave
6by9
Thu Jul 23, 2020 7:37 am
rpi_ft5406 was upstreamed and became raspberrypi-ts https://github.com/raspberrypi/linux/bl ... rrypi-ts.c
g8gkq
Fri Jul 24, 2020 1:28 pm
Thanks to @jamesh and @6by9 for the replies.
1. I have changed my reference to 'ft5406' to 'raspberrypi-ts' in the dmesg grep and that has solved the first problem.
2. The update changed the default framebuffer depth from 32 bit to 16 bit (found by running fbset). I was able to change it back to 32 bit by commenting out (both) 'dtoverlay=vc4-fkms-v3d' lines in /boot/config.txt, and now my direct pixel write works again. In due course I may modify the routine to work with 16 bit framebuffer depth, so that my application is compatible with the default configuration.
My final problem is off-topic, in that I can't get the Waveshare 3.5 inch touchscreen to work. One for another day and another topic!
Thanks again
Dave, G8GKQ
techrep
Re: Recent Update Has Changed Framebuffer Parameters - Solved
Fri Jul 24, 2020 7:02 pm
All, I can confirm Dave's experience and his method of resolving same. I was building HamClock (https://www.clearskyinstitute.com/ham/HamClock/) for the RPi model 4 and ran into this same issue.
I exchanged several emails with the dev who was helpful but unable to resolve. I've since reported back to him what was done to resolve the issue.
73,
Chris, KD6OUB
trejan
Fri Jul 24, 2020 7:15 pm
Does adding framebuffer_depth=32 to the end of /boot/config.txt fix it?
It was probably using fbtft_device which was removed in 5.4. The new 5.4 approved method is to have a DT overlay for it that configures fbtft. Try https://github.com/swkim01/waveshare-dtoverlays
g8gkq
Fri Jul 24, 2020 7:31 pm
Hi @trejan
No, adding framebuffer_depth=32 at the end of /boot/config.txt does not fix it without commenting out dtoverlay=vc4-fkms-v3d and then the framebuffer_depth command is not required.
It was an outdated DT overlay (dating from the days of Jessie) that was the problem with the Waveshare touchscreen. I replaced it with one from swkim01 and it sorted the problem.
Thanks!
Dave, G8GKQ
6by9
Fri Jul 24, 2020 7:59 pm
The frame buffer depth was updated by upstream as the buffer otherwise became wasted memory once the DRM/KMS driver took over, so wasting 50% of the memory by using RGB565 instead of RGBX8888 was seen as a good thing.
Now the only thing I can't recall is where that change was! I would have thought device tree, but I don't immediately see it there.
g8gkq
Fri Jul 24, 2020 10:12 pm
Thanks @6by9. So for future compatibility (assuming that I'm going to continue writing to the framebuffer for my graphics) would you recommend that I amend my code to write RGB565 instead of changing the framebuffer depth and writing RGBX8888?
Dave
