DaedalusOS
Display Resolution Issue
Fri Nov 01, 2019 9:06 pm
Greetings!
I've spent the past hour attempting to figure this out, to no avail...
I've hooked up my Raspberry Pi 4 to the 7" Touchscreen Display, and unfortunately I'm running into an issue with the resolution being larger than the display itself.
Output of tvservice -s:
state 0x400000 [LCD], 800x480 @ 60.00Hz, progressive
I have overscan disabled, and I made sure that /boot/config.txt doesn't have anything with overscan enabled in there.
The right side of my screen is cut off, I can't see the clock, and I can move the mouse off the physical screen. The touch is also offset, so if I touch anywhere on the screen, the mouse is about a centimeter to the right...
Any ideas?
Thanks!
Re: Display Resolution Issue
Fri Nov 01, 2019 9:17 pm
Weird.
What version of Pi, what version of OS and are you using FKMS or legacy graphics?
DaedalusOS
Fri Nov 01, 2019 9:28 pm
Weird.
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
I did just run raspi-update earlier as well, to no avail.
As for graphics, how would I tell that? (I'm still somewhat new to this, sorry!)
Side note, when I run xwininfo -root, I get "-geometry 848x480+0+0"
DaedalusOS
Sat Nov 02, 2019 3:29 pm
Weird.
Thanks for the hint above with this post, I went through /boot/config.txt and I found the following line:
dtoverlay=vc4-fkms-v3d
Once I put a "#" before that and rebooted, everything is now literally fine. The touch is accurate and the screen resolution issue is now resolved.
Thanks!
