xSyn
Screen for Raspberry Pi
Mon Jul 15, 2019 1:26 pm
Hi. Noob question here.
I was wondering which screens can be able to connect to a Raspberry Pi (I’m using a Raspberry Pi 3 model A).
Can I get any machine with an lcd screen (like a TV, a photo framework, a laptop,…) and connect it to the raspberry?
Thank you.
W. H. Heydt
Re: Screen for Raspberry Pi
Mon Jul 15, 2019 4:35 pm
There are two output jacks for video on a Pi3A+. The main one is HDMI. That should work with any display that has either an HDMI or DVI-D input. The other is a composite video output that is combined with the analog audio output in a 4-pole 3.5mm jack.
In addition--and the specific topic for this sub-forum--is the RPF 7" touchscreen that connects through the DSI connector on the board. There are a variety of third party small displays, usually up to 3.5" that connect through the GPIO block, but for those you have to modify the boot control files, /boot/cmdline.txt and /boot/config.txt.
HawaiianPi
Mon Jul 15, 2019 5:39 pm
TV, yes, using either HDMI or composite video. Also DVI with a HDMI to DVI-D adapter (or VGA, but VGA adapters are often troublesome).
Assuming "photo framework" means a digital picture frame, it would depend on whether or not it had an external video input (probably not).
Laptop, tablet, smartphone can connect to a Pi using VNC remote desktop and the RealVNC viewer (VNC server is included with Raspbian). For CLI access you can use SSH. In this example screenshot from my Win10 PC, the upper-left window is a VNC remote desktop connection to my new Pi 4B, and the terminal is an SSH connection to my headless Creeper Pie Minecraft SMP server running on a 3B+ model.
xSyn
Tue Jul 16, 2019 10:45 am
Ahhhh thank you guys!
I'm sorry I was refering to the display one (not the HDMI one). So, if I were to remove the lcd screen from an iPad (for example), could I connect it to the rapsberry changing the boot file as you said? And that could work with any lcd screen?
RaTTuS
Contact: Twitter YouTube
Tue Jul 16, 2019 12:44 pm
no , not easily - what is wrong with an HDMI display
Covfefe
gkaiseril
Tue Jul 16, 2019 5:05 pm
There is also the 7" lcd for the dsi.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
aBUGSworstnightmare
Tue Jul 16, 2019 7:28 pm
there is no simple way for connecting a random display ro a Pi.
HermannSW
Mon Jul 29, 2019 10:42 am
I do use 7" Waveshare DPMI lcd, few lines added to /boot.config.txt needed only.
Advantages: bigger resolution (1024x600); cheaper
Disadvatages: raw display, no frame; only 18bit color; no touch
Besides the 18bit color restriction that came as a surprise to me last year, I like the display. Pure display is good enough in the provided stand, and my wireless USB keyboard has touch:
https://www.raspberrypi.org/forums/view ... 5&t=219214
https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/github_repo_i420toh264
W. H. Heydt
Mon Jul 29, 2019 5:27 pm
I have to admit that I'm quite curious about the camera you're using. Care to share the make and model?
HermannSW
Fri Aug 02, 2019 3:54 pm
One of those cheap (now <4$) v1 camera clones (not NoIR):
https://www.raspberrypi.org/forums/view ... 9#p1507039
with self added M12 mount:
https://www.raspberrypi.org/forums/view ... 7#p1279957
and lens taken from this NoIR v1 camera:
https://www.aliexpress.com/item/1000001803139.html
P.S:
Lately I like capturing with mode 1 because that is identical for v1 and v2 cameras.
And half size 960x540 preview fits perfectly on 7" 1024x600 DPMI LCD.
I like v1 camera, because unlike v2 camera it allows for global external shutter capturing, see signature.
