with ice cream
Control original blanker?
Tue Jun 04, 2019 1:41 pm
Is there a way to control the original screen blanker? Is there a way to get the current state? /sys/class/backlight/rpi_backlight/bl_power doesn't seem to be related to the original screen blanking function.
Currently, if I want to wake the screen without user interaction I simulate a mouse click with xdotool. I'd also would like to know the screen's state and to programmatically force the screen to go blank.
Is using xscreensaver the only workaround/alternative?
klricks
Re: Control original blanker?
Wed Jun 05, 2019 1:00 pm
xset commands are used to control screen blanking.
To see current settings:
xset q
There are 2 screen blanking functions running at the same time, both with 10 min. defaults. You have to turn both off to disable screen blanking:
xset s 0
xset -dpms
(I usually turn off the dpms and work with the xset s commands)
To force screen blank:
xset s activate
To unblank:
xset s reset
also see:
xset -?
man xset
-Note the RPi does not support all the available xset commands.
-xset commands do not work if xscreensaver is installed.
-The above works with HDMI monitors. Never tried with official display..
-All xset commands revert to defaults on reboot. To make permanent you need to add the commands to autostart.
with ice cream
Wed Jun 05, 2019 6:45 pm
Perfect. Thank you, the 's' options work. The only remaining issue is that I cannot query the screen's state when I disable dpms. I'll experiment some more.
