Sotolotl
Can you hotplug the official display?
Wed Apr 10, 2019 7:07 am
As the title says, is it possible to hotplug a DSI display? I'm using an official Raspberry Pi 7" touchscreen display attached to a Pi 3 B+. Ideally, I'd like a DSI equivalent to hdmi_force_hotplug in config.txt so that I can boot the pi and power the display later.
Thanks!
6by9
Re: Can you hotplug the official display?
Wed Apr 10, 2019 8:24 am
No.
- The connector really isn't designed for it, so you'll get lots of nastiness at an electrical level if you are genuinely hotplugging it.
- IIRC The I2C peripheral on the display board isn't an open drain, so pulls the lines down if it loses power.
- The firmware isn't set up to send the initialisation sequence to the board at any point other than boot.
Sotolotl
Wed Apr 10, 2019 4:59 pm
Thanks for the clarification. I'll look into other ways of doing what I need :)
