Hi there,
I'd like to wall mount my Pi so it can control the heating.
Looking for wall mounting cases I did not found much and the obvious choice seems to be the official Pi case.
However, I am concerned as that case hosts the Pi at the bottom (or top if you want) and there is no bezel where the Pi sits. If I cut a hole in my wall, then I'd be able to see the edges of the hole if the case is not covering it - do I make sense?
Am I missing something here?
Tony
