Laughing Gnome
Display problems
Wed Aug 29, 2018 4:47 pm
Hi, I was given a screen for xmas last year and had it set up perfectly. Ihavent used it for a few months and when I tried to get it going all i get is this:-
Any one know whats going on. PI is working ok and using hdmi to tv it does as it should.
Many Thanks
Re: Display problems
Wed Aug 29, 2018 7:17 pm
Pull off the green & yellow wires. You don't need those with any of the 40-pin Raspberries.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
Laughing Gnome
Wed Aug 29, 2018 7:46 pm
No green and yellow wires attached just red & black attached to 5v and ground.
Wed Aug 29, 2018 8:12 pm
Power off. Pull the ribbon cable (carefully, so you don't break the connectors). Reinstall the ribbon. Reboot & test.
Laughing Gnome
Thu Aug 30, 2018 10:22 am
Still no joy. It also stays the same if I power it up with the ribbon cable disconnected. I think it may have had its day. Shame. Thanks for your help.
Laughing Gnome
Fri Aug 31, 2018 3:46 pm
Seems the problem was with the pi rather than the screen. Guessing there is a problem with the pins as the pi works ok using hdmi.
Fri Aug 31, 2018 3:52 pm
Most likely problem is a broken ribbon cable. That's a £2 fix from eBay.
https://www.ebay.co.uk/itm/Hearty-CSI-F ... 1280713876
Return to “Official Foundation Display”
