Billibob
Touchsreen and Hdmi trouble (Lakka)
Mon Jul 30, 2018 8:55 pm
I recently bought an official 7 inch touchscreen for my pi3.
I only only use the program Lakka.
Unfortunatly, since I connected the screen, my hdmi output is not working. (Black screen)
The only way I found to make it work is to edit config.txt with a lcd_ignore=1 command, but this is not user friendly as well.
Do yo have a better solution for me to switch the dsi port and the hdmi port easily ?
Thank you
:D
aBUGSworstnightmare
Re: Touchsreen and Hdmi trouble (Lakka)
Tue Jul 31, 2018 2:47 pm
start reading this viewtopic.php?f=63&t=216399
to get some Background info on the Topic, than start fromk here viewtopic.php?f=63&t=216399&start=50#p1346976
Billibob
Wed Aug 08, 2018 1:43 am
I found a simple solution that I will share with you guys.
-I have installed Noobs on a micro sd card ;
-On the first boot, I have selected Lakka + Lakka Dev to install. So, it created 2 partitions with 2 config.txt on the same sd card ;
-I have edited both config.txt with those differents settings :
Config.txt on Lakka :
lcd_ignore=1, hdmi_hotplug=1,
hdmi_boost=4 and hdmi_safe=2
Config.txt on Lakka reg :
rotate_display=1
So, when Noobs boot, I cant selected with the touche screen on witch partition Lakka will boot. Lakka Dev for the Hdmi port or Lakka reg for the dsi (touchscreen) port.
It works perfectly !
Have a nice one and thanks for you help.
