jitto
Broken touch panel
Fri May 25, 2018 10:45 pm
In an attempt to fit the official 7 inch display in a US double DIN space (car audio head unit), I broke the glass touch panel. The board and LCD works fine. Is there a replacement touch panel I can buy? Or if I get it elsewhere (ebay), what specification should I look for?
I checked with local supplier and they do not provide any support and cannot replace since I broke it.
The US double DIN has a height of 4 inches (approx 101 mm) and the official screen's height is just 110 mm. If RPF is planning a revised version, lowering the height to 101 mm or lower will help a lot of folks trying to use the LCD display in their car.
jcommisso
Re: Broken touch panel
Sat Jun 23, 2018 5:17 pm
I have the same exact problem. While I was fitting it to my car, it came loose and fell, cracking the top right corner. Touch no longer works. I pried the capacitive panel off of the LCD using a credit card, and now I just have a regular LCD. Apparently, there are no digitizer replacements, as seen here: viewtopic.php?f=108&t=149308
I guess I'll just have to spend $70 and be more careful next time...
Who is online
Users browsing this forum: No registered users and 2 guests
