KanoMaster22
Using USB to power touchscreen
Tue Nov 21, 2017 1:30 pm
Quick question, would it be possible to power the Pi touchscreen using USB? Maybe with the use of a USB breakout.
KanoMaster22
Re: Using USB to power touchscreen
Tue Nov 21, 2017 4:51 pm
Sorry stupid question! Just been doing more research it turns out you have to power it from an external power supply or from the GPIO ports. Why can't it be plugged in the the Pis USB ports but it can be powered from the GPIO pins. Is it that the GPIO pins provide more current.
KanoMaster22
Tue Nov 21, 2017 4:53 pm
Wait, I am talking to myself here but is this https://www.modmypi.com/raspberry-pi/ac ... ower-cable saying I can power the touchscreen and pi from one power supply?
alphanumeric
Sat Nov 25, 2017 1:35 pm
You can power both from one power supply, providing that power supply can provide enough current to run both. The cable you linked to, powers the Pi from the display board. Your power supply would be plugged into the micro USB on the display board. There are also Y cables out there. Your power supply plugs into it, then it splits to two cables, one plugs into the Pi and one to the display.
I made my own cables up. My display and Pi are both powered from a common power supply.
KanoMaster22
Sun Nov 26, 2017 4:25 pm
Thanks for the help. The cable included with the SmartiPi Touch case(http://cpc.farnell.com/smarticase/smt2n ... dp/SC14549) looks like it should do the job as I am getting the case anyway and I already have a suitable power supply.
alphanumeric
Sun Nov 26, 2017 5:22 pm
That's the Y cable (or reasonable facsimile) I've seen. on a few sites. It should work out OK for you.
KanoMaster22
Mon Nov 27, 2017 3:50 pm
Okay.
Thanks again for your help.
Return to “Official Foundation Display”
