JayinHouston
Official Rapberry Pi Touchscreen
Thu Apr 06, 2017 3:26 pm
I just purchased the 7 inch Touchscreen display and Smarticase for my Pi. I wanted to know if it's possible to change the resolution on the screen so I can see even more of the webpages when online. Even if it means everything appears smaller. I tried tvservice -m CEA and tvservice -m DMT, but no luck. Also, does anyone know if there is a way to reduce the brightness? Thank you.
Raspberry Pi 3B running Raspian Jessie. Smarticase with Raspberry Pi Official 7" Touchscreen.
Houston, TX USA
W. H. Heydt
Re: Official Rapberry Pi Touchscreen
Thu Apr 06, 2017 5:02 pm
To control the backlight brightness:
echo 250 > /sys/class/backlight/rpi_backlight/brightness
The range is 0 to 255.
Like any LCD display, the imgae is best viewed at the screens native resolution. As I understand it, tvservice is for controlling the HDMI interface, not the DSI that the RPF screen attaches to.
ktb
Thu Apr 06, 2017 5:11 pm
I could be wrong, but I don't think changing the official touchscreen resolution is possible.
EDIT: I'm wrong. I've been using the 4.9.x kernel with VC4 drivers. When using vc4-fkms-v3d, the touchscreen is apparently treated as HDMI-1. Using vc4-kms-v3d, both HDMI-1 and DSI-1 (for the touchscreen) are available. However, xrandr does not appear to be able to change the mode/resolution. Well, maybe... Using vc4-kms-v3d, the ARandR GUI tool makes it look like DSI-1 supports 800x480 and 1312x744 (weird), but 1312x744 doesn't work properly. Using vc4-fkms-v3d, setting framebuffer_width=1280 and framebuffer_height=720 in config.txt does sort of work (but mouse cursor position is way off, while touch input appears to be accurate).
Reducing the screen brightness is easily done when using the Xfce desktop environment with xfce4-power-manager. I don't know of an easy way to do that when using PIXEL or LXDE, unless xfce4-power-manager works in PIXEL/LXDE (I've never tried).
EDIT: xfce4-power-manager does appear to work in LXDE. Using the "Show system tray icon" option, a right click on the icon will pop-up a menu with a slider control for adjusting the "Display brightness."
JayinHouston
Thu Apr 06, 2017 6:13 pm
W. H. Heydt wrote:To control the backlight brightness:
Do I type that code into the terminal? I was getting an access denied error.
Houston, TX USA
JayinHouston
Thu Apr 06, 2017 6:34 pm
I actually just learned from more searching that the resolution can be adjusted in the terminal using
sudo nano /boot/config.txt
I changed my resolution to 1200x720. I still can't change the brightness however...
Houston, TX USA
kusti8
Thu Apr 06, 2017 6:44 pm
You have to be root. One way is to enter a root shell:
sudo su
W. H. Heydt
Thu Apr 06, 2017 10:00 pm
Prefix the command with "sudo" so that you are running it with root privileges. My setup runs it as part of the root cron, where one starts by usung "sudo crontab -e", putting the command in there (no sudo needed, it will already sun as root).
W. H. Heydt
Thu Apr 06, 2017 10:01 pm
kusti8 wrote:You have to be root. One way is to enter a root shell:
sudo su
That's overkill for a single command. All it takes is using sudo as a command prefix. (And--FYI--if I want to run as root for a while, I prefer "sudo su -" so that I get the full root environment.)
JayinHouston
Thu Apr 06, 2017 10:27 pm
W. H. Heydt wrote: Prefix the command with "sudo" so that you are running it with root privileges. My setup runs it as part of the root cron, where one starts by usung "sudo crontab -e", putting the command in there (no sudo needed, it will already sun as root).
i typed in
sudo echo 250 > /sys/class/backlight/rpi_backlight/brightness
and got this error:
bash: /sys/class/backlight/rpi_backlight/brightness: Permission denied
got the same thing when i typed in sudo su instead of just sudo.
Houston, TX USA
Thu Apr 06, 2017 10:36 pm
sudo sh -c "echo 250 > /sys/class/backlight/rpi_backlight/brightness"
I'll do your homework for you for a suitable fee.
JayinHouston
Fri Apr 07, 2017 2:58 am
DougieLawson wrote:sudo sh -c "echo 250 > /sys/class/backlight/rpi_backlight/brightness"
Yes! It worked!
Houston, TX USA
kusti8
Fri Apr 07, 2017 10:58 am
sudo su
When piping into a file in Linux, you can't just prefix echo with sudo because the file still won't have permissions. You could use tee or the way dougie showed, but just prefixing it won't work
PuppetHoundZ
Sat Apr 22, 2017 1:41 am
Another Recomendation is to use Chromium and when in default resolution use your keyboard and press Ctrl and the Negative symbol - to adjust the webpage size formatting. It works like a charm with all websites and keeps the Resolution footprint down allow you to play HD videos down-scaled to 480p and it's amazing.
Off topic but leaving the resolution at default and down-scaled with Chromium allows you to play Youtube 60fps @720p down-scaled to 480p (default resolution). The High Frame Rate makes for some very amazing sights for such a low res screen.
