Sparks135
Official display resolution
Wed Apr 05, 2017 4:32 pm
I have the official 7" touchscreen, and display properties says 1024x600. Everything is very small, so how do I change this? There is no pulldown in Display Properties.
Re: Official display resolution
Wed Apr 05, 2017 11:23 pm
The official display is 800x480.
[email protected]:~$ tvservice -s
state 0x400000 [LCD], 800x480 @ 60.00Hz, progressive
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
Sparks135
Thu Apr 06, 2017 3:19 am
DougieLawson wrote:The official display is 800x480.
I used sudo nano /boot/config.txt and changed it there. Thanks. it looks so much better, or should I say bigger.
marcopic
Sun Mar 11, 2018 10:26 am
Yes, it's true but resolution in Raspberry Pi Configuration is "default 720x480".
What is the "real" resolution?
I got an issue with the Arduino program window; its upper side goes beyond the upper edge of the screen and I can't manage the window
ab1jx
Sun Mar 11, 2018 8:31 pm
The real hardware resolution is 800x480. You may call it something else close and have it sort of work, but whatever you specify is getting scaled to 800x480. Using the native 800x480 will look sharpest.
Who is online
Users browsing this forum: No registered users and 4 guests
