end kernel panic not syncing
Posted: Tue Nov 29, 2016 4:32 am
by martipe1
the display behavior is odd, this what I can see:
1. rainbow screen
2. bright frame around the screen
3. cycles several times
4. error can't create /sys/class/leds/led0/trigger: nonexistent directory
5. menu screen to select OS
6. white screen
7. 4 raspberrys
8. bright frame around the screen
9.rainbow screen
10. black screen
11. go back to 4
and sometimes can get the subject error
I'm sure is a display issue as connected to an external monitor I have no problem
Thanks,
Re: end kernel panic not syncing
Posted: Tue Nov 29, 2016 4:11 pm
by martipe1
I setup the display as per the following page https://thepihut.com/blogs/raspberry-pi ... mbly-guide
Posted: Tue Nov 29, 2016 4:32 pm
by 6by9
Unlikely to be your problem, but disconnect the white and grey wires (SCL and SDA) - they are only needed on the original model A and B.
PiHut need a nudge to update their howto (as, I think, do Element14).
Posted: Wed Nov 30, 2016 2:47 am
by martipe1
I did try but no luck
Is it possible that it is due to a bad display?
What about the error can't create /sys/class/leds/led0/trigger: nonexistent director ?
Posted: Wed Nov 30, 2016 10:13 am
by 6by9
TBH I'd download a fresh copy of Raspbian (not NOOBS), install it on a new card, and see what that does.
Connect a monitor to the HDMI connector at the same time, as the Pi will default to that if it fails to detect the DSI screen.
Double check the connector from controller board to the LCD screen too - if that is slightly off then you could get something quirky, although if you sometimes see the 4 raspberries correctly then it is probably not that.
Posted: Thu Dec 01, 2016 5:33 am
by martipe1
I checked out the connector and looks fine, here you can see the problem I have https://youtu.be/rUOQDjZTT88
Posted: Thu Dec 01, 2016 7:31 am
by 6by9
That little yellow lightning bolt in the top right means your power supply isn't up to the job. You Pi is most likely browning out.
Get a better power supply, or use one of the other approaches for linking power between the display and the Pi.
Posted: Fri Dec 02, 2016 10:39 pm
by martipe1
I want to thank you
Yes, the problem was due to the power supply
I thought the yellow lighting meant that it was connected :lol:
