We’re using the official 7″ Touchscreen Monitor together with a raspberry pi 2. Sometimes the display fades to white/black and freezes (the pi is still responsive). A power cycle is required to recover from this state, reboot does not normally work.
The pi fails to detect the display and defaults to NTSC video mode.
During normal operation:
tvservice -s
state 0x400000 [LCD], 800x480 @ 60.00Hz, progressive
dmesg | grep rpi-ft5406
[ 3.553003] rpi-ft5406 rpi_ft5406: Probing device
After failure :
tvservice -s
state 0x40001 [NTSC 4:3], 720x480 @ 60.00Hz, interlaced.
(returns nothing)Is there any way to recover from this state except power cycle?
I will try to reduce the I2C0 clock rate. Any other suggestions?
I have followed the troubleshooting guide @ https://www.raspberrypi.org/documentati ... hooting.md:
- Reseated all cables.
- Checked power supply. No glitch outside 4.75 – 5.25 V detected with oscilloscope. No rainbow square.
Hardware:
Raspberry Pi 2 Model B V1.1
Raspberry Pi Display V1.1
OS:
RASPBIAN JESSIE Full desktop image based on Debian Jessie
Version:May 2016
Release date:2016-05-27
Kernel version:4.4
OS upgraded according to instruction @ https://thepihut.com/blogs/raspberry-pi ... mbly-guide:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo apt-get install raspberrypi-ui-mods
sudo apt-get install raspberrypi-net-mods
uname -a
Linux raspberrypi 4.4.13-v7+ #894 SMP Mon Jun 13 13:13:27 BST 2016 armv7l GNU/LinuxSeparate bench PSU @ 5V, 3A for rpi and display, shared ground.
Thank you for your time!
/ge0x58
