Hi
Not sure if this is in the right section, hopefully so!
I am trying to create a multi boot system with Raspian, Rasplex and probably Kali.
I have a raspi 3 connected to an official touchscreen. If i install rasping on its own or via noobs the touchscreen works perfectly. However if i use Berry boot (which i want to as i can select OS' of my choice, the touch part of the screen does not work. the display is fine but no touch is registered.
Any idea how to get touch working on Berryboot installs?
I am using the latest version of berryboat and raspian and doing an update and upgrade of rasping once installed,
Any help is most appreciated
David
