EchoEum
Re: [How To] Two finger touch for right click
Sun Feb 05, 2017 4:30 am
I cant make the file. I'm getting the following when I run make.
gcc -c -Wall -O2 twofingemu.c
In file included from twofingemu.c:17:0:
/usr/include/linux/input.h:12:22: fatal error: sys/time.h: No such file or directory
 #include <sys/time.h>
compilation terminated.
Makefile:12: recipe for target 'twofingemu.o' failed
make: *** [twofingemu.o] Error 1
mikeh8020
Thu Mar 02, 2017 6:04 pm
I get to the "twofing --debug" part and I get the following message.
twofing, the two-fingered daemon
Version 0.1.2.20120708
Input device name: "FT5406 memory based driver"
XInput device ID is 7.
XInput device ID for calibrations is 7.
Start Calibration
No calibration data found, use default values.
No valid axis inversion data found.
The hardware:
Pi3B
Official 7" touchscreen
The software:
Raspbian Jessie
RetroPie installed (manual installation on top of Jessie)
ibex
Mon Mar 06, 2017 11:30 am
I have got exactly the same problem as reported by mikeh8020.
Thank you for any help in advance!
mikeh8020 wrote:I get to the "twofing --debug" part and I get the following message.
Start Calibration
The hardware:
Pi3B
The software:
Raspbian Jessie
aerowolf
Wed Apr 12, 2017 5:18 am
Make that three of us... :?
I've attempted following this short tutorial and checking out the information given at http://plippo.de/p/twofing to no avail. If anyone has sorted out a way to resolve this issue I'd love to hear it. Until then I'm going to keep banging my head against the wall. It has to crack eventually right?
Metallode
Wed Apr 12, 2017 3:43 pm
i think that i found @EchoEum
use
sudo apt-get install libxtst-dev
or spécificly rewritte this
 sudo apt-get install build-essential libx11-dev libxtst-dev libxi-dev x11proto-randr-dev libxrandr-dev
EDIT: sorry, aerowolf it was for @EchoEum
aerowolf
Wed Apr 12, 2017 8:46 pm
Metallode wrote:i think that i found
use
So what you've done is replace the step where you install the libs
with this instead?
In that case, I'm guessing I should remove all of the other items and just leave libxtst-dev installed. Here's what I'll try when I get a chance:
sudo apt-get autoremove build-essential libx11-dev libxi-dev x11proto-randr-dev libxrandr-dev
cd twofing-0.1.2
make
sudo cp twofing /usr/bin/
twofing --debug
I've already got the rules file in place, and I'm assuming everything still compiles correctly without the other libs. If I misinterpreted your comment let me know...it'll be a while before I can test it anyway.
wolfmanjm
Thu Apr 20, 2017 11:35 pm
I get the infamous "No valid axis inversion data found."
This stops it running. I solved it by making a simple change to the code...
https://github.com/Plippo/twofing/blob/ ... mu.c#L1036
change this line to..
readCalibrationData(0);
Then recompile.
Then it seems to work.
FlipPI76
Fri Apr 21, 2017 12:49 am
Everyone who is having problems with Jessie and the debug message "No valid axis inversion data found".
I think I found a workaround... Additional to the installation procedure in the beginning of this thread, I performed the following steps:
Install evdev driver
sudo apt-get install xserver-xorg-input-evdev
Modify X11-conf (in Jessie it's here: /usr/share/X11/xorg.conf.d)
sudo nano /usr/share/X11/xorg.conf.d/40-libinput.conf
At the end of the file add:
Section "InputClass"
   Identifier "calibration"
   Driver "evdev"
   MatchProduct "FT5406 memory based driver"
   Option "EmulateThirdButton" "1"
   Option "EmulateThirdButtonTimeout" "750"
   Option "EmulateThirdButtonMoveThreshold" "30"
EndSection
Create a new rule-file
sudo nano /etc/udev/rules.d/70-touchscreen-raspberrypi.rules
Add the lines below
KERNEL=="event*",ATTRS{name}=="FT5406 memory based driver",SYMLINK+="twofingtouch",MODE="0440"
Reboot your device
sudo reboot
After reboot check the X11-logfile
cat /var/log/Xorg.0.log
There you should find something like:
  • [ 13.726] (II) config/udev: Adding input device FT5406 memory based driver (/dev/input/event0)
    [ 13.727] (**) FT5406 memory based driver: Applying InputClass "evdev touchscreen catchall"
    [ 13.727] (**) FT5406 memory based driver: Applying InputClass "libinput touchscreen catchall"
    [ 13.727] (**) FT5406 memory based driver: Applying InputClass "calibration"
    [ 13.727] (II) LoadModule: "evdev"
    [ 13.728] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
    [ 14.621] (II) Module evdev: vendor="X.Org Foundation"
    [ 14.622] compiled for 1.18.4, module version = 2.10.3
    [ 14.622] Module class: X.Org XInput Driver
    [ 14.622] ABI class: X.Org XInput driver, version 22.1
    [ 14.622] (II) Using input driver 'evdev' for 'FT5406 memory based driver'
    [ 14.622] (**) FT5406 memory based driver: always reports core events
    [ 14.622] (**) evdev: FT5406 memory based driver: Device: "/dev/input/event0"
    [ 14.623] (--) evdev: FT5406 memory based driver: Vendor 0 Product 0
    [ 14.623] (--) evdev: FT5406 memory based driver: Found absolute axes
    [ 14.623] (--) evdev: FT5406 memory based driver: Found absolute multitouch axes
    [ 14.623] (II) evdev: FT5406 memory based driver: No buttons found, faking one.
    [ 14.623] (--) evdev: FT5406 memory based driver: Found x and y absolute axes
    [ 14.623] (--) evdev: FT5406 memory based driver: Found absolute touchscreen
    [ 14.623] (II) evdev: FT5406 memory based driver: Configuring as touchscreen
    [ 14.623] (**) Option "EmulateThirdButton" "1"
    [ 14.623] (**) Option "EmulateThirdButtonTimeout" "750"
    [ 14.624] (**) Option "EmulateThirdButtonMoveThreshold" "30"
    [ 14.624] (**) evdev: FT5406 memory based driver: YAxisMapping: buttons 4 and 5
    [ 14.624] (**) evdev: FT5406 memory based driver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
    [ 14.624] (**) Option "config_info" "udev:/sys/devices/virtual/input/input0/event0"
    [ 14.624] (II) XINPUT: Adding extended input device "FT5406 memory based driver" (type: TOUCHSCREEN, id 6)
    [ 14.624] (II) evdev: FT5406 memory based driver: initialized for absolute axes.
    [ 14.625] (**) FT5406 memory based driver: (accel) keeping acceleration scheme 1
    [ 14.625] (**) FT5406 memory based driver: (accel) acceleration profile 0
    [ 14.626] (**) FT5406 memory based driver: (accel) acceleration factor: 2.000
    [ 14.626] (**) FT5406 memory based driver: (accel) acceleration threshold: 4
Now start twofing with debug option
twofing --debug
and you should see
  • twofing, the two-fingered daemon
    XInput device id is 6.
    XInput device id for calibration is 6.
    Start calibration
    Calibration: MinX: 0; MaxX: 800; MinY: 0; MaxY: 480
    Invert X Axis: No
    Invert Y Axis: No
    Swap Axes: No
    Calibration Matrix: 1.000000 0.000000 0.000000
    0.000000 1.000000 0.000000
    Grab Result: 0
    Reading input from device ... (interrupt to exit)
    Current window: 'lxtermin'
    Use default profile.
Now twofing should work...
Cheers,
Flip
FlipPI76
Fri Apr 21, 2017 3:11 am
For the sake of completeness, here the complete installation from scratch...
# Install packages
sudo apt-get update && sudo apt-get install build-essential libx11-dev libxi-dev x11proto-randr-dev libxrandr-dev libxtst-dev xserver-xorg-input-evdev
# Install twofing
cd ~
wget http://plippo.de/dwl/twofing/twofing-0.1.2.tar.gz
tar -xvzf twofing-0.1.2.tar.gz
cd twofing-0.1.2
make && sudo make install
# create a new rule-file
# add the following line
# modify X11 config
# add the following lines at the end of the file
   Driver "evdev"
EndSection
# Reboot your device
sudo reboot
# Check if twofing is working
twofing --debug
# Add twofing to autostart
nano ~/.config/lxsession/LXDE-pi/autostart
# add the line at the end
@/usr/bin/twofing
# Cleanup
cd ~
rm -rf ~/twofing-0.1.2
Tozzi1
Fri Apr 21, 2017 5:41 pm
Works like a charm. Thanks a lot, I've been pulling my hair out over this.
Webmets
Mon Aug 07, 2017 10:22 am
   Driver "evdev"
EndSection
Add the lines below
Reboot your device
sudo reboot
twofing --debug
and you should see
    Start calibration
    Invert X Axis: No
    Invert Y Axis: No
    Swap Axes: No
    Grab Result: 0
Cheers,
Flip
After following these steps, twofing works, but now whenever I start twofing from commandline, my desktop disapears, and the file manager crashes. Any idea how that happend?
daniel_e
Thu Aug 10, 2017 12:12 pm
I keep getting this annoying error, as I have gone through everything at least 4 times... I can't find my mistake. Can anyone help?
/dev/twofingtouch: No such file or directory
skinkone
Mon Nov 06, 2017 10:03 am
Just wanted to thank you: this worked for me except I had to change "FT5406 memory based driver" to "USBest Technology SiS HID Touch Controller" for my Hannspree 27" touchscreen monitor. Perhaps that's an obvious mod to the majority of people reading this, but to someone like me who is just slightly more capable than a trained monkey in all things Linux ( :mrgreen: ), it could end the frustration!
paulkonp
Sun Apr 01, 2018 10:53 pm
Two finger support is working with the instructions by @FlipPI76, however I'm unable to get single finger long-press right-click to work.
Is there a simple way to enable long-press for single finger that will show the right-click context menu? I'm using Quanta OpticalTouchScreen device.
Thanks.
robiv8
Mon Jun 11, 2018 10:07 pm
So i have :
Linux Testrechner 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
I do all step by step but no luck!
pi@Testrechner:~ $ twofing --debug
My /etc/udev/rules.d/70-touchscreen-egalax.rules:
KERNEL=="event*",ATTRS{name}=="eGalaxTouch Virtual Device for Multi",SYMLINK+="twofingtouch",RUN+="/bin/chmod a+r /dev/twofingtouch"
Any help please?
il_diavolo
Sat Aug 24, 2019 7:58 pm
Anyone got this to work with Buster?
My set up is an early Pi2B and the official 7" screen. I had twofing working correctly with Stretch but it doesn't work after a fresh install of Buster, following the installation instructions in this thread.
The error I get when I type "twofing --debug" in a terminal window is
EDIT Just noticed this is the same error that robiv8 in the post above had with Stretch. I'm non the wiser though!
il_diavolo
Sun Aug 25, 2019 9:17 pm
So, I've solved it myself, sorry to have bothered you all.
The solution is to add the missing bit to:
which is:
KERNEL=="event*",ATTRS{name}=="FT5406 memory based driver",SYMLINK+="twofingtouch",RUN+="/bin/chmod a+r /dev/twofingtouch",MODE="0440"
Cheers
Redhatter
Sat Oct 12, 2019 1:00 am
I figured I'd share this here… since some of the posts have been a big help to getting multi-touch working. I've bundled the above fixes into a Debian package.
Basically, there's a fork of twofing that added Debian packaging, and I forked that some time ago to add a udev rule file for the Raspberry Pi touch-screens.
My fork of a fork is here: https://github.com/sjlongland/twofing
I've submitted this as a pull request upstream. Update: this has been accepted upstream.
To build: install the dependencies mentioned earlier in this thread, then run
dpkg-buildpackage -us -uc -b
. You'll be left with a .deb file which may then be deployed on any Raspberry Pi with a 7" screen attached.
huunguyen
Thu Nov 21, 2019 10:09 am
fixed on buster for ras pi 3
sudo apt install input-utils
sudo ln -s /dev/input/event0 /dev/twofingtouch
Pydat
Thu Apr 16, 2020 6:05 pm
Hello !
I've a Asus VT168H touchscreen plugged and I've follow all the topic.
Have going true the installation (the updated one).
Get some adjustment from some user to fit some bug.
Then I am stuck with the --debug,
I've got the "No valid axis inversion data found".
But maybe I have a clue: (???)
When I call the --debug, the terminal told me that he's calling the xinput ID 6, but when I do a xinput-list, my touchscreen is on ID 9 "ELAN touchscreen"
How could I force/call the programme to get the correct ID ??
Also I might say that I'm a newborn linux user with all that it should mean...
Amicalement,
bokismoki777
Tue May 19, 2020 7:40 pm
As one Linux noob to another, I proudly report I have just succesfully implemented two-finger touch for Asus VT168H on RasPi 3B and Raspbian Stretch. So first of all, thank you all for your invaluable contributions!
I can confirm the instructions from FlipPI76 work. The only thing that needs to be altered is the device name of the touchscreen. Asus VT168H registers in Raspbian as device "ELAN Touchscreen", which can be verified with command "xinput list" or with inspecting the /var/log/Xorg.0.log.
So, alternate step #1: Edit /usr/share/X11/xorg.conf.d/40-libinput.conf file
   Driver "evdev"
   MatchProduct "ELAN Touchscreen"
EndSection
Alternate step #2: Create a new udev rule-file. You can name it anything you like (except for the '70-' prefix which is there to ensure the proper order of processing multiple rule files). I chose to name mine after Asus and ELAN, because it contains configuration based on this specific touchscreen:
sudo nano /etc/udev/rules.d/70-touchscreen-asusELAN.rules
Add the following line:
KERNEL=="event*",ATTRS{name}=="ELAN Touchscreen",SYMLINK+="twofingtouch",MODE="0440"
That's it. After reboot two-finger tap worked like a charm!
Lowkeycoat
Tue Jun 02, 2020 9:15 pm
i am also getting error
when i type in "ls -l /dev/twofingtouch " i get
ls: cannot access '/dev/twofing': No such file or directory
typed in "ls -l /etc/udev/rules.d/70-touchscreen-egalax.rules" got
-rw-r--r-- 1 root root 123 Jun 2 21:45 /etc/udev/rules.d/70-touchscreen-egalax.rules
and this is my sudo nano /etc/udev/rules.d/70-touchscreen-egalax.rules
i cannot for the life of me find what i did wrong. ths is the most current raspbian os
i did a fresh install 2 days ago all upgraded&&updated
plz help thanks in advanced :)
RobertMcLean
Sat Jul 18, 2020 8:58 pm
I have Official 7" touch screen and Raspbian downloaded and updated today 18 Jul 2020.
When I follow the instructions given by FlPi76, which have worked for some people here, I have the following problems
1) after sudo apt-get update && etc
I get error messages Could not open lock file /var/lib/dpkg/lock-fronteend etc
and
Unable to acquire the dpkg frontend lock etc are you root ?
I am new to Linux, but I thought sudo made me super user, or root ? Am I misunderstanding that ? do I need to do something to fix this ?
But I thought I would continue with the instructions anyway, maybe I was lucky and did not need updates since I did a fresh install today.
But after make && sudo make install gcc -c-Wall -02 twofingemu.c
I got fatal error :X11/extensions/XTest.h no such file of directory
Am I missing a file ? Should I just add that file and retry ?
Thanks for any suggestions
bokismoki777
Mon Jul 20, 2020 9:35 am
"sudo" does make you root (super user). There is nothing else you need to do. I've never encountered your specific problem before, but I found this article which might give you a clue how to proceed: https://itsfoss.com/could-not-get-lock-error/. But like you said, updating may not be absolutely necessary if you installed a fresh OS. But the fact that the lock file exists is not a good sign in itself.
As for your second error, the internet suggests installing a missing package "libxtst-dev":
So you might try that. But the question is why is the package missing? And what else might be missing as well? Which Raspbian did you install? I would definitely recommend "Raspberry Pi OS (32-bit) with desktop and recommended software" from https://www.raspberrypi.org/downloads/raspberry-pi-os/.
RobertMcLean
Mon Jul 20, 2020 5:58 pm
Thank you, I have it all working now.
The lock problem just went away, the information at itsfoss.com makes me think there was just something else running at the time, but I have no idea what.
I installed the libxtst-dev. The suggested Raspberry Pi OS (32-bit with desktop and applications is what I had installed, so I dont know why I got that error.
To add TwoFing to autostart I put it in /etc/xdg/lxsession/LXDE-pi/autostart
When I added lxsession/LXDE-pi directories to .config and put an autostart in there
the result was the normal start up was short circuited and I did not get the "normal" graphical screen, I got a black screen
and right clicking on it gave me a menu for OpenBox or some name like that. Fortunately I could open a terminal from there and undo what I did, and change the autostart file at /etc/xdg/lxsession/LXDE-pi/
I realize now I could have left it in .config/lxsession/LXDE-pi and called up the /etc ... autostart first, but its working now, so I think will leave it alone.
