official 7" touchscreen LCD black lcd & no power up!!
Posted: Sun Dec 20, 2015 2:04 pm
by gaeran
Hello?.
I have problem with my official 7" LCD. please help!!
The ribbon cable is fine and connected right way.
when I power up, the screen shows nothing and back-light is not work.
I have had powering two ways.
5V -> pi -> lcd : not working
5V -> lcd -> pi : not working.
here is what I did.
1. new image download RASPBIAN JESSIE (Released 2015-11-21)
2. sudo apt-get update
3. sudo apt-get upgrade
4. sudo rpi-update
5. sudo reboot
6. lsmod
[email protected]:~ $ lsmod
Module Size Used by
evdev 10552 4
cfg80211 399468 0
rfkill 16799 2 cfg80211
r8188eu 432632 0
snd_bcm2835 19739 3
snd_pcm 75040 1 snd_bcm2835
snd_timer 18668 1 snd_pcm
bcm2835_gpiomem 3023 0
snd 52620 9 snd_bcm2835,snd_timer,snd_pcm
uio_pdrv_genirq 2986 0
uio 8228 1 uio_pdrv_genirq
i2c_dev 6108 0
fuse 82598 3
ipv6 343236 30
[email protected]:~ $ dmesg|grep -i ft5406
7. add "dtoverlay=rpi-ft5406" on /boot/config.txt
sudo vi /boot/config.txt
sudo reboot
[ 4.997104] rpi-ft5406 rpi_ft5406: Probing device
[ 4.997293] rpi-ft5406 rpi_ft5406: Touchscreen not detected
I have no idea with this.
Please help.
Thank you.
Regards,
Kevin.
Re: official 7" touchscreen LCD does not work!!
Posted: Sun Dec 20, 2015 4:18 pm
by ulix
What does not work?
Have you connected the ribbon cable the right way? All cables the right way?
Most displays work out of the box, with the new raspbian (as well as with wheezy) :!:
Posted: Mon Dec 21, 2015 2:23 am
by gaeran
Thank you for the reply.
ribbon cable is fine. all right way. I've checked out many times. but the screen is black.
I didn't think about try with wheezy. but the JESSIE is the new one right?.
I'll try wheezy today. let you know the results.
many thanks.
Regards,
ulix wrote:What does not work?
Posted: Mon Dec 21, 2015 9:22 am
by ulix
I don't think it's the distro. The display must flash up when powering up...
How did you do the power supply for the display?
Posted: Mon Dec 21, 2015 9:32 am
by gaeran
I've tried
1. power from pi
2. smartphone power supply
3. usb power from pc
not tested lcd power to pi.
is there led on lcd board for identify power activity?.
how can I figure out the lcs board is working properly?
do you have a test method of lcd board?
Thank you.
Regards,
Posted: Mon Dec 21, 2015 9:35 am
by RaTTuS
a decent 2A+ PSU
power the display from that
power the RPI from the Display
Posted: Mon Dec 21, 2015 10:46 am
by ulix
The display wont work if it is powered after the rpi.
Like mentioned from RaTTus first driver board display then from there rpi.
Posted: Mon Dec 21, 2015 11:50 pm
by gaeran
Hi RaTTuS, ulix,
power lcd -> pi.
It was not effective for me.
I rather check my lcd board.
Is it possible damage on lcd board if I feed 5.13V for the lcd power?
How can I get my lcd board's status dead or alive?
Thank you.
How can I get Official 7" lcd board is dead or alive?
Posted: Wed Dec 23, 2015 1:22 am
by gaeran
Hello?.
Symptom :
1. the screen shows nothing = black
2. back-light not work.
The flat ribbon cable is fine, connected right way.
I have had powering up two ways.
The pi OS image is newest version and upgraded.
I have tried may ways to revive my lcd screen. but it gives me pain.
So, I would like to check the lcd board's condition.
I have a basic electronic tester and dso138 oscilloscope. but not a expert of electronics.
Do you have any test sequence for the lcd board's condition?
Any suggest is welcome.
Thank you.
Best Regards,
Kevin.
Re: official 7" touchscreen LCD black lcd & no power up!!
Posted: Wed Dec 23, 2015 11:43 am
by texy
Kevin please don't keep raising new threads on the same subject.
Texy
Posted: Thu Dec 24, 2015 10:07 pm
by ulix
Since there are no schematics it's hard to troubleshoot.
I personaly think it has something to do with the supply voltage. Could you measure it on the lcd board?
Please add some pics of you setup with the display! Then we can investigate further...
And I don't think you will break it with 5.2V.
Posted: Fri Dec 25, 2015 7:24 am
by gaeran
Hi ulix,
Yesterday, I had asked to local Rpi distributor for check out the AD board status.
I believe they will shipping for RMA if it was defective.
or I could buy a new lcd. :(
Happy Christmas!!
Thank you.
Regards,
Kevin.
Posted: Fri Dec 25, 2015 10:22 am
by ulix
please keep us posted! ;)
Posted: Tue Jan 05, 2016 6:23 am
by lanewinfield
This was happening to me too, until I realized I was being an idiot and the SD card had slipped out a bit—are you sure it's properly seated?
Posted: Thu Jan 07, 2016 6:39 am
by gaeran
I've got answer from local distributor.
In my case, (I was remove USB port and 5 pin from AD board as below image link) because of my AD board was modified. they can not process RMA.
So, I asked them if I can buy a new AD board, and answer was NO.
This is so bad case.
Regards,
Kevin.
Posted: Thu Jan 07, 2016 9:33 am
by hansotten
gaeran wrote:Hi,
Regards,
Kevin.
Indeed bad luck. But the distributor is right, modifying a board as you did is always a valid reason for refusing warranty.
Are you sure (you did not tell us you did this mod!) the mod is not the cause of your problems? Removing an USB port is quite some surgery.
Posted: Thu Jan 07, 2016 12:29 pm
by gaeran
hansotten wrote:
gaeran wrote:Hi,
Regards,
Kevin.
Yes, I had confirmed no problem after I soldering for the stuffs off.
Thank you anyway.
Regards,
Kevin.
Posted: Sun Jan 10, 2016 11:05 pm
by ulix
Maybe we can find the error.
Could you post some pictures from the board? So we can see how the desoldering was done?
Then we could look into the board...
Posted: Mon Jan 11, 2016 5:58 am
by gaeran
ulix wrote:Maybe we can find the error.
You can see a picture with below link.
http://thingiverse-production-new.s3.am ... atured.jpg
thank you.
Posted: Mon Jan 11, 2016 7:55 am
by texy
thank you.
..I think he means a much closer view of the desoldered connector ;)
Texy
Posted: Fri Feb 05, 2016 9:46 am
by gaeran
Sorry for late update.
I've just get back my LCD and AD board from local distributor. Now I found AD board was defected.
I would like to revive the AD board if I could Please help!
https://goo.gl/photos/hsSQXQunL8HNCarM9
https://goo.gl/photos/pnLz7QNQowFeL8738
Thank you.
Posted: Fri Feb 05, 2016 9:55 am
by texy
Unfortunately you voided the warranty by attempting rework yourself, but I wish you luck......
Texy
Posted: Fri Feb 05, 2016 11:22 pm
by gaeran
Sorry but, I can't find warranty guide for my lcd. Do you know where is the warranty guide for lcd?
I just have safety guide in my box.
texy wrote:Unfortunately you voided the warranty by attempting rework yourself, but I wish you luck......
Texy
