mbostrum
Can the front black frame be removed
Fri Dec 11, 2015 12:50 pm
I'm looking for at 7" display for my pi and this would be perfect except for the black framed front. Can this front be removed?
jdb
Re: Can the front black frame be removed
Fri Dec 11, 2015 1:32 pm
No. It's a single piece of glass.
Rockets are loud.
https://astro-pi.org
mbostrum
Fri Dec 11, 2015 4:01 pm
So that is the touch screen then, I suppose?
tinylcd
Sat Dec 12, 2015 4:48 am
Hello
In case you are looking for a high resolution 7 inch display with 1024x600 pixels without touch screen than
you can see if below option can meet your need
http://www.neosecsolutions.com//product ... 8&cPath=21
regards
Tinylcd
karlkiste
Sat Dec 12, 2015 11:10 am
The front glass is not the touchscreen, it is a decorative frame. The touch glass is behind that glass, but not at the center. If you want to try that you can cut the front glass a bit smaller. Just holding a ruler near the glass I'd say you could cut off like 4 and 11mm at the long axis, and 6 and 2mm at the small axis. So the size could re reduced from 194x110mm to 179x102mm with the usable display off-center.
Greets,
Kiste
karlkiste
Sat Dec 12, 2015 11:16 am
Oh, and if you don't need touch: Some people have complained the glue coming off. You could try with moderate heat (like 50°C) and gentle pulling for some hours or some days to remove the front glass, the touch glass, or both.
Greets,
Kiste
