I'm interested in the Pi and its peripherals. I was wondering if it would be possible to connect the touchscreen, possibly using an adapter, as a secondary monitor on a PC. Or is the touchscreen compatible exclusively with the Pi? Any replies will be appreciated.
Sam
- Raspberry Pi Engineer & Forum Moderator
- Location: ZZ9 Plural Z Alpha, aka just outside Cambridge.
Re: Can I use the Pi Touchscreen with a different Computer?
Almost zero chance on a PC.FinalSmash wrote:I'm interested in the Pi and its peripherals. I was wondering if it would be possible to connect the touchscreen, possibly using an adapter, as a secondary monitor on a PC. Or is the touchscreen compatible exclusively with the Pi? Any replies will be appreciated.
The Pi touchscreen uses DSI and I2C as the interfaces, neither of which are generally available on a PC.
You might be able to hook it up to a Beagleboard or Freescale board, but don't expect any support in trying to do so.
That answers my question. Thanks.
It would almost certainly be possible to design a replacement control board that would adapt the screen the screen to DVI and USB. However it would not be a trivial task.
