Dan K
Pi + Display = ePub Reader
Tue Oct 27, 2015 9:35 pm
Got my official Raspi display yesterday. Way Cool!!
Thought it might make a nice ePub reader.
With a bit of googling I came across Lucidor which is free and can run on Debian Linux.
It has a requirement for XULRunner and the docs recommend to have Firefox installed which includes XULRunner. That turned out to be problematic on the Pi. However there is a fork of Firefox named Iceweasel which can be installed on the Pi from the command line with:
sudo apt-get install iceweasel
Once Iceweasel is installed you can get the deb package for Lucidor with:
wget http://lucidor.org/get.php?id=lucidor_0.9.10-1_all.deb
This will download a file named
which I renamed:
mv get.php?id=lucidor_0.9.10-1_all.deb lucidor_0.9.10-1_all.deb
Then installed the package with:
sudo dpkg -i lucidor_0.9.10-1_all.deb
After a reboot I added Lucidor to the Pi's desktop menu under:
Menu > preferences > Main Menu Editor > New Item
with
command: Lucidor
I copied a couple of ePubs from my Windows system using WinSCP to test things out and it works great. Pubs are full color and in-page links work just fine. Lucidor even has a full screen mode which can be controlled from the Lucidor file file nenu.
I first set this up on a B+ pi with a fresh install of Raspbian Jessie but it was a bit slow so I moved the SD card to a Pi2 and it performs wonderfully.
gadgetoid
Re: Pi + Display = ePub Reader
Wed Oct 28, 2015 2:22 pm
I've always been a fan of fbreader ( since using it on the Nokia n800 ):
sudo apt-get install fbreader
slinskiy
Thu Oct 19, 2017 2:32 pm
Thank you. FB Reader was a painless process to install.
ab1jx
Fri Mar 02, 2018 3:09 am
Calibre has a reader as well as pretty much everything you need for changing formats and maybe publishing. It's not fast though, maybe just the reader is. It's in the standard debs.
