Joan Carles
About official Raspberry 7" Display
Tue Oct 20, 2015 9:38 am
Hi everyone!
I bought it, but I need to remove the touch screen.
Is it possible to take off the touch screen from the display?
Thank you!!
RaTTuS
Re: About official Raspberry 7" Display
Tue Oct 20, 2015 9:56 am
why do you need to remove it ?
and probably not
Covfefe
Tue Oct 20, 2015 10:02 am
Joan Carles wrote:Hi everyone!
Thank you!!
The Blog does clearly state:
Touchscreen
The Raspberry Pi display has an integrated 10-point touchscreen
https://www.raspberrypi.org/blog/the-ea ... i-display/
Retired disgracefully.....
scotty101
Tue Oct 20, 2015 10:18 am
You could disable the touchscreen functionality but you can't physically remove it!
Joan Carles
Tue Oct 20, 2015 12:37 pm
I need to remove because I want to put into a determinate place.
I will try to cut :D
Thank you so much!
Tue Oct 20, 2015 12:39 pm
Joan Carles wrote:I need to remove because I want to put into a determinate place.
Thank you so much!
Why not just buy a non-touch screen :?:
Joan Carles
Tue Oct 20, 2015 1:09 pm
Is there anyone?
Spectre
Tue Oct 20, 2015 2:05 pm
It seems possible: viewtopic.php?f=108&t=123287
joemensor
Tue Oct 20, 2015 8:39 pm
Yep - you can remove it. Use a hair dryer to warm up the glass touchscreen and peel it away...carefully... from the the TFT display underneath.
tallika_fan
Wed Oct 21, 2015 10:20 am
scotty101 wrote:You could disable the touchscreen functionality but you can't physically remove it!
I'm looking at making a portable media center with the touchscreen, though what options are available for disabling and re-enabling touchscreen for input, could it be accomplished via a GPIO connected switch?
Thanks.
Pete
LeZandre
Thu Oct 22, 2015 8:49 pm
Thank you!!
I had mine on non-stop for three weeks when I was away on holiday.
Today I read up on the forum about the problems with the touch screen detaching itself.
I checked up on my contraption (touchscreen mounted 'ribbon cable up' in this stand : e.g. ' http://swag.raspberrypi.org/collections ... play-frame ').
The ensemble was lukewarm and the touchscreen had completely detached itself.
So yes, the touchscreen is detacheable. Even if you don't want to.
