ValDog
Touch does not work on official RPi display
Sat Sep 26, 2015 10:17 pm
I've done all the recommended things (update, upgrade, rpi-update) and checked that the small cable is firmly seated, but can't seem to get the screen to respond to touches. Anyone else seeing this issue?
Ws4u
Re: Touch does not work on official RPi display
Mon Sep 28, 2015 11:29 am
same here.
The first time i started the gui with "startx" the touch screen did work.
Now it is no longer possible to get the touch functionality to work again. Tried all the hints in this forum with no result.
Any ideas? Is it possible to check if there are some kind of driver errors?
rubinio
Mon Sep 28, 2015 12:00 pm
Same here. also tried everything. I wrote am mail to swag. Maybe ist broken :-(
gadgetoid
Mon Sep 28, 2015 1:22 pm
Once updating with rpi-update ( which I believe is now unnecessary since apt-get update && apt-get upgrade will now install the fix ) I haven't seen any further problems with the touchscreen across multiple displays.
This is worth a try, to bring you back into the world of sanity rather than pre-release;
sudo apt-get install --reinstall raspberrypi-bootloader
sudo reboot
Let me know if it helps.
rubinio
Mon Sep 28, 2015 4:01 pm
It helped. Big thanks.
ValDog
Mon Sep 28, 2015 9:36 pm
gadgetoid wrote:Once updating with rpi-update ( which I believe is now unnecessary since apt-get update && apt-get upgrade will now install the fix ) I haven't seen any further problems with the touchscreen across multiple displays.
sudo reboot
Appreciate the feedback, but still not solved for me...
gsh
Tue Sep 29, 2015 5:49 am
1) If you do lsmod is rpi-ft5406 listed?
2) Install evtest (sudo apt-get install evtest) then run it... Touch the screen do you get anything out of the driver?
Gordon
Gordon Hollingworth PhD
ValDog
Tue Sep 29, 2015 1:23 pm
rpi-ft5406 is listed when I run lsmod.
Running evtest I get no response when I touch the screen.
gsh
Sun Oct 04, 2015 4:44 pm
Sounds like a faulty touchscreen...
