ZoeReed
Compute Module
Fri Sep 25, 2015 2:31 pm
I am trying to get my compute module to work with the new official Raspberry Pi 7 inch touchscreen and can't seem to get it to work. However, I can get it to work via HDMI to a monitor.
Can someone please help me with getting the compute module to work with the rpi LCD?
W. H. Heydt
Re: Compute Module
Fri Sep 25, 2015 3:29 pm
Is the OS & firmware on you CM up to date?
Does your CM carrier board have a DSI connector?
ZoeReed
Re: Compute Module
Fri Sep 25, 2015 3:36 pm
It is completely up to date.
It has two display connectors and came with an adapter board, but when I connect the touchscreen to that it doesn't seem to do anything on the screen.
RaTTuS
Contact: Twitter YouTube
Re: Compute Module
Fri Sep 25, 2015 3:50 pm
are they RPi B type ones and not B2 type ones ?
Covfefe
ZoeReed
Re: Compute Module
Fri Sep 25, 2015 3:55 pm
It's the compute module so its not related to either.
RaTTuS
Re: Compute Module
Fri Sep 25, 2015 4:00 pm
yes but is the DSI wired up like B or B2 ports they are differnt
Covfefe
PeterO
Re: Compute Module
Fri Sep 25, 2015 4:04 pm
A little background info as to why Rattus is asking about B vs 2B
As and Bs didn't have the i2C port on the DSI connector , so if the CM's connector is wired like and A or B it won't work until the fix for the A and B is produced.
A+s B+s and 2B+s all have the needed I2C port wired up on the DSI connector.
HTH
PeterO
RaTTuS
Re: Compute Module
Fri Sep 25, 2015 4:07 pm
Thank's PeterO ... v busy here today :)
Covfefe
gsh
Re: Compute Module
Fri Sep 25, 2015 5:09 pm
It probably just needs the camera I2C set up in the dt-blob.bin (the display shares this) But I'm not absolutely sure and haven't had the time to check it out yet... Should be able to get around to that next week
Gordon
Gordon Hollingworth PhD
Raspberry Pi - Director of Software Engineering
ZoeReed
Re: Compute Module
Wed Sep 30, 2015 8:23 am
How would the dt-blob.bin help me with connecting the display seen as all I have read about it is that it is to do with the camera, which I don't want.
gsh
Re: Compute Module
Wed Sep 30, 2015 10:16 am
Actually if you make sure the DSI I2C connections are connected from GPIO pins 28, 29 it may work...
Again it's something else I've got to look at but haven't yet had time
Gordon
ZoeReed
Re: Compute Module
Wed Oct 07, 2015 9:21 am
Had a go at the wiring but could not get the screen to appear. Could have possibly wired it up wrong but don't want to fiddle with it in case something breaks...
b1gtuna
Re: Compute Module
Mon Oct 26, 2015 8:38 pm
Any luck on this by any chance?
ZoeReed
Re: Compute Module
Tue Oct 27, 2015 9:26 am
No, I didn't. Moved on to just playing with the Pi2 for now. Will most likely end up going back to the Compute module.
b1gtuna
Re: Compute Module
Tue Oct 27, 2015 3:17 pm
Thanks. I'm taking a stab at it. No success yet =(
ZoeReed
Re: Compute Module
Tue Oct 27, 2015 3:20 pm
I had a good go at it myself, but due to the fact that I have a list of things I need to do with the compute module and the Pi 2, I thought it be best to see what I can do on the Pi 2 first seen as I have that working.
Good luck, let me know if you make any progress with it :D
b1gtuna
Re: Compute Module
Wed Oct 28, 2015 12:32 am
Just got it to work - read my thread - viewtopic.php?p=835160#p835160
tl;dr version is to include this snippet in the CM section of your dt-blob:
pin_define@DISPLAY_I2C_PORT {
type = "internal";
number = <0>;
The number 0 indicates I2C-0. Apparently without this, it looks for the display at I2C-1.
ZoeReed
Re: Compute Module
Wed Oct 28, 2015 9:17 am
Thanks, I will give it a go and see how I get on :D
6by9
Re: Compute Module
Wed Oct 28, 2015 10:40 am
b1gtuna wrote:Just got it to work - read my thread - viewtopic.php?p=835160#p835160
I think you missed a bit. You need to add:
pin_define@DISPLAY_SDA {
type = "internal";
number = <28>;
pin_define@DISPLAY_SCL {
type = "internal";
number = <29>;
type = "internal";
number = <0>;
and link CD1_SDA and CD1_SCL on J6 (pins 37 & 39) to GPIOs 28&29 (J6 pins 1&3).
Display to be connected to the DISP1 connector.
Return to “Official Foundation Display”
