bedtime
Re: [how to] enable long touch as right click
Wed May 08, 2019 12:14 pm
MeneerJansen wrote:
Wed Apr 10, 2019 6:55 pm
The shell script from @bedtime gives the following error on my Raspbian 9.8 Stretch machine in Xfce:
usage: xinput query-state <device name>
/home/pi/bin/rclk.sh: 30: [: =: unexpected operator
Sorry about that. Haven't used that script in a long time...
If it's a touchscreen device, you can try replacing the line:
MOUSE_ID=$(xinput --list | grep -i -m 1 'mouse' | grep -o 'id=[0-9]\+' | grep -o '[0-9]\+')
with
MOUSE_ID=$(xinput --list | grep -i -m 1 'FT5406' | grep -o 'id=[0-9]\+' | grep -o '[0-9]\+')
C program to find the device of a touchscreen:
printevent.c:
    gcc -Wall -O3  printevent.c -o printevent
#include<stdio.h>
__inline void fast_memcpyS(char *str, const char *str2, int start, int len)
    for( ;len > -1; )
        str[len + start] = str2[len];
        --len;
__inline int fast_memcmp(const char *str, const char *str2, int len)
    while(str[len] == str2[len] && --len);
    return len;
void get_device()
    char data[120], s[32];
    int ret;
    FILE * const file = fopen( "/proc/bus/input/devices", "r");
    do
        ret = fscanf(file, "%*2s %s %*[^\n]\n", data);
    while(fast_memcmp(data, "Name=\"FT5406", 12) != 0 && ret != EOF);
    fscanf(file, "%*[^\n]\n%*[^\n]\n%*[^\n]\n%*2s %*15s %6s", data);
    fast_memcpyS(s, "/dev/input/", 0, 11);
    fast_memcpyS(s, data, 11, 6);
    puts(s);
    fclose(file);
int main() {
    get_device();
    return 0;
MeneerJansen
Wed May 08, 2019 6:45 pm
Solved it by adding this to /etc/X11/xorg.conf.d/99-calibration.conf:
   # Right mouse button is long press with pen:
   Option "EmulateThirdButton" "1"
   Option "EmulateThirdButtonTimeout" "750"
   Option "EmulateThirdButtonMoveThreshold" "30"
[edit 16-6-2019] It must be added in the section called "InputClass".
Asymic
Sun Jun 16, 2019 8:39 am
Please can someone expand on the last post, quoting "solved it".
Is this all I have to do to get a long touch on Jessie?
I am quite new to Pi. The line "Solved it by adding this to /etc/X11/xorg.conf.d/99-calibration.conf: " is a little confusing to me.
I take it that this is the path:- "/etc/X11/xorg.conf.d/" and this is a file name:- "99-calibration.conf"
If that is the case, and this is a new file, How does Pi know to read it?
Thank you.
MeneerJansen
Sun Jun 16, 2019 2:50 pm
Thank you.
I think that my "method" only works in Raspbian 9 "Stretch". And yes, the path is "/etc/X11/xorg.conf.d/" and the filename is "99-calibration.conf". If you don't have that file on your Pi then I don't think it will work. By the way, all files in /etc/X11/xorg.conf.d/ are read and executed when Linux starts up. By the way, the text must be added in the section called "InputClass" in said file.
If you're new to the Pi and to Linux then trying to get a TFT screen to work on Raspbian Stretch may be quite difficult. See this topic.
Asymic
Tue Jun 18, 2019 3:59 pm
Thank you for the answer. I am running "Stretch" so I am a little confused as to why you would have the folder, and I have not.
I really need this long press feature! Do you think adding the folder and making the file would produce a result?
Thank you!
MeneerJansen
Wed Jun 19, 2019 10:44 am
Thank you!
You may have another LCD touch screen than I have. I had to download "drivers" (read: some sripts) from the manufacturers' website. Those create said files and folders.
irdroid3
Fri Jun 28, 2019 6:06 pm
Does anyone know how to enable the long touch for the right mouse button
in Buster / Debian 10 (on the Official Touch screen on a Raspberry Pi 4) ?
I poked around looking for - /etc/X11/xorg.conf.d/99-calibration.conf
but the similariry ends at - /etc/X11/
Cheers, Ian
MeneerJansen
Sat Jun 29, 2019 11:04 am
Cheers, Ian
You might try to create it. Maybe it'll work... If not, this topic might be of help if you're an experienced Linux user.
