misc
Compatibility Openelec
Wed Sep 23, 2015 8:40 am
I am curious whether the new 7" display does its job under Openelec. Does somebody have experience with that, does it work ?
Michael
gsh
Re: Compatibility Openelec
Wed Sep 23, 2015 10:51 am
I believe that current OpenELEC has not been updated recently enough, but the milhouse builds are suitable
Gordon
Gordon Hollingworth PhD
misc
Wed Sep 23, 2015 11:24 am
This helped a lot. Thank you.
Michael
bigjayman
Fri Sep 25, 2015 7:54 am
gsh wrote:I believe that current OpenELEC has not been updated recently enough, but the milhouse builds are suitable
Gordon
I downloaded the latest milhouse build and the screen still doesn't work. Am I possibly missing a setting?
misc
Fri Sep 25, 2015 9:26 am
I had no problem at all, it worked out of the box. No modification or changes necessary.
bigjayman
Fri Sep 25, 2015 11:43 am
misc wrote:I had no problem at all, it worked out of the box. No modification or changes necessary.
That's weird. I used Leopold add-on to download the latest Milhouse build, it updated then rebooted and still nothing. Did you update anything else or is that all you did?
misc
Fri Sep 25, 2015 11:47 am
I had the latest downloadable OpenElec on my sdcard. (Firmware for LCD is missing) After that i downloaded the latest milhouse build and put the tar into the update-folder, that's it.
muzza1973
Thu Jan 07, 2016 11:07 am
guys I have openelec 15.2 running on my RPI - 2 with the 7" touchscreen. I am getting audio dropouts every 5 secs (using the analogue jack to amplified speakers). Tried different RPIs and different builds. Seems when the touch screen is attached the outcome is the same.
Any ideas ?
Cheers
