Raspbian Jessie?
Posted: Thu Sep 17, 2015 11:13 pm
by Tuerai
Does anyone have the official display running on Raspbian Jessie?
I couldn't get my TFT LCD screen from Adafruit that used the GPIO pins to work on Jessie, but I figured this one seems to be a bit easier to setup. I haven't tried yet due to lack of a spare micro SD card.
Re: Raspbian Jessie?
Posted: Sat Sep 19, 2015 4:08 pm
by gsh
Yeah works fine
Posted: Mon Sep 28, 2015 7:34 pm
by icebob
Yes, I'm using official display on Jessie. This is the tutorial:
https://medium.com/@icebob/jessie-on-ra ... 3b8d80e7e1
Posted: Tue Sep 29, 2015 7:54 pm
by paultnl
I would disagree that it "works fine", it runs the screen upside down. I know the solution is trivial but it should have been included in the default settings as standard not left as another trap to put off NOOBs
Posted: Tue Sep 29, 2015 8:01 pm
by PeterO
paultnl wrote:I would disagree that it "works fine", it runs the screen upside down. I know the solution is trivial but it should have been included in the default settings as standard not left as another trap to put off NOOBs
When it comes up that way round for the first time how will it be a trap ? It's only been an issue for the early adopters who got the 1st release of the firmware upgrade AND had also had a stand.
PeterO
Posted: Tue Sep 29, 2015 8:03 pm
by Boomer
Ugh. I just did the installation on my display. I'm getting a little tired of the bleeding edge. Think I'll wait for a simpler solution before updating.
Jack
Posted: Tue Sep 29, 2015 8:17 pm
by Tuerai
Boomer wrote:Ugh. I just did the installation on my display. I'm getting a little tired of the bleeding edge. Think I'll wait for a simpler solution before updating.
After someone said it worked, I just changed my sources.list entries to jessie, and did an "apt-get dist-upgrade". I said no to both of the proposed "new versions of existing config files" and then rebooted after it finished, and mine still works. So if you install it under wheezy, and then upgrade to jessie it works.
Posted: Tue Sep 29, 2015 9:06 pm
by paultnl
I was talking about the official release on the download page so it is not just early adopters who are affected by this.
Posted: Tue Sep 29, 2015 9:15 pm
by MikeDunn
Yes, it works on a clean load; agreed it's a pain that we still have to put in the rotate fix, but ...
Mike
Posted: Tue Sep 29, 2015 9:21 pm
by PeterO
paultnl wrote:I was talking about the official release on the download page so it is not just early adopters who are affected by this.
From now on people who get the latest Jessie and put it on a machine with the 7" display will not have a problem. It will be the "right way up" to start with and they will never know it was originally the other way up.
PeterO
Posted: Wed Sep 30, 2015 9:24 am
by paultnl
PeterO
Even if they are not using a stand the power connectors would be on the bottom which can be a problem with some cables. Surely it would be easier to fix this than keep making excuses.
Posted: Wed Sep 30, 2015 3:12 pm
by Boomer
How do you "change" the source.list entries? Not sure what that means....
Jack
