Feature request: Entries in /dev/input/by-id
Posted: Mon Sep 14, 2015 8:54 pm
by PeterO
Can appropriate links be added to /dev/input/by-id for the touch screen device please ?
These entries are useful for finding a particular device by name, for example on my desk top machine:
petero@HP /dev/input/by-id $ ls -l
total 0
lrwxrwxrwx 1 root root 9 Sep 14 19:03 usb-CHICONY_HP_USB_Multimedia_Keyboard-event-if01 -> ../event3
lrwxrwxrwx 1 root root 9 Sep 14 19:03 usb-CHICONY_HP_USB_Multimedia_Keyboard-event-kbd -> ../event2
lrwxrwxrwx 1 root root 9 Sep 14 19:03 usb-Logitech_USB_Trackball-event-mouse -> ../event4
lrwxrwxrwx 1 root root 9 Sep 14 19:03 usb-Logitech_USB_Trackball-mouse -> ../mouse0
As you can see this means you can find the correct "event" or "mouse" entry to use to pick up events from a particualr device when more that one is present.
Currently on my PI I have entries in /dev/input for a USB keyboard, a USB tracker ball and the touch screen, but no matching entry in /dev/input/by-id for the touch screen.
pi@raspberrypi /dev/input $ ls -l
total 0
drwxr-xr-x 2 root root     120 Sep 14 21:46 by-id
drwxr-xr-x 2 root root     120 Sep 14 21:46 by-path
crw-rw---T 1 root input 13, 64 Jan  1  1970 event0
crw-rw---T 1 root input 13, 65 Jan  1  1970 event1
crw-rw---T 1 root input 13, 66 Jan  1  1970 event2
crw-rw---T 1 root input 13, 67 Sep 14 21:46 event3
crw-rw---T 1 root input 13, 63 Jan  1  1970 mice
crw-rw---T 1 root input 13, 32 Jan  1  1970 mouse0
crw-rw---T 1 root input 13, 33 Sep 14 21:46 mouse1
pi@raspberrypi /dev/input $ cd by-id
pi@raspberrypi /dev/input/by-id $ ls -l
total 0
lrwxrwxrwx 1 root root 9 Jan  1  1970 usb-04f3_0103-event-if01 -> ../event1
lrwxrwxrwx 1 root root 9 Jan  1  1970 usb-04f3_0103-event-kbd -> ../event0
lrwxrwxrwx 1 root root 9 Sep 14 21:46 usb-Logitech_USB_Trackball-event-mouse -> ../event3
lrwxrwxrwx 1 root root 9 Sep 14 21:46 usb-Logitech_USB_Trackball-mouse -> ../mouse1
THese are useful when developing openGL ES code that needs to get user input from a mouse,keyboard or touch screen :-)
I'm not sure where these entries get created.
PeterO
Re: Feature request: Entries in /dev/input/by-id
Posted: Tue Sep 15, 2015 12:03 pm
by PeterO
A quick look google has shown me that this is a "udev rules" issue, and in fact it looks like suitable rules should already exist but I'll have to wait until I'm in front of a PI to check if they are present on the PI.
This looks helpful too : http://arakilab.media.eng.hokudai.ac.jp ... n-example/
PeterO
Posted: Sat Sep 26, 2015 2:41 pm
by PeterO
pi@raspberrypi ~ $ udevadm info -a -p /devices/virtual/input/input2/event2
Udevadm info starts with the device specified by the devpath and then
walks up the chain of parent devices. It prints for every device
found, all possible attributes in the udev rules key format.
A rule to match, can be composed by the attributes of the device
and the attributes from one single parent device.
  looking at device '/devices/virtual/input/input2/event2':
    KERNEL=="event2"
    SUBSYSTEM=="input"
    DRIVER==""
  looking at parent device '/devices/virtual/input/input2':
    KERNELS=="input2"
    SUBSYSTEMS=="input"
    DRIVERS==""
    ATTRS{name}=="FT5406 memory based driver"
    ATTRS{phys}==""
    ATTRS{uniq}==""
    ATTRS{properties}=="2"
Based on the above information, I'm not sure what a symlink for the touchscreen in /dev/input/by-id should be called.
Posted: Fri Mar 04, 2016 1:16 pm
by PeterO
Having just been bitten by this problem again while getting demos ready for the PiParty this weekend I though I'd post the solution :D
pi@2PiBP1 /etc/udev/rules.d $ cat 95-touch.rules
SUBSYSTEM=="input", ATTRS{name}=="FT5406 memory based driver", ENV{DEVNAME}=="*event*", SYMLINK+="input/by-id/FT5406-events-touch"
pi@2PiBP1 /etc/udev/rules.d $ ls -l /dev/input/by-id
total 0
lrwxrwxrwx 1 root root 9 Mar  4 13:10 FT5406-events-touch -> ../event2
lrwxrwxrwx 1 root root 9 Mar  4 13:10 usb-CHICONY_HP_USB_Multimedia_Keyboard-event-if01 -> ../event1
lrwxrwxrwx 1 root root 9 Mar  4 13:10 usb-CHICONY_HP_USB_Multimedia_Keyboard-event-kbd -> ../event0
PeterO
