PeterO
Official touch screen unreliable [Solved / Firmware updated]
Sun Sep 13, 2015 5:14 pm
I'm finding the touch screen on the official display to be very unreliable.
I'm reading and parsing the events from the touchscreen via /dev/input/events2 (events0 and events1) are associated with the USB keyboard I have attached to the PI.
it seems the touch screen hardware regualrly locks up in some way and stops generating event. I've also seen the cursor in Xwidows freeze. So far the only way I've found to restore correct operation if to power cycle the PI. Unloading and reloading the kernal module has no effect.
Has anyone else seen this behaviour or have I got a faulty interface ?
PeterO
scotty101
Re: Official touch screen unreliable
Sun Sep 13, 2015 9:49 pm
I've seen similar 'lockups'. I had attributed it to Florence but it way just be because I was touching the screen more often whilst typing with the onscreen keyboard.
PeterO
Sun Sep 13, 2015 9:54 pm
scotty101 wrote:I've seen similar 'lockups'. I had attributed it to Florence but it way just be because I was touching the screen more often whilst typing with the onscreen keyboard.
Yes I noticed it with Florence as well, but I've also seen it happen with X when not using Florence and when not running X but using evtest or my own code to read the events from /dev/input
PeterO
Sun Sep 13, 2015 10:09 pm
PeterO
Apart from Florence in the Repository there is xvkbd
Another alternative is onboard https://launchpad.net/onboard
Thinking outside the box is better than burying your head in the sand...
PeterO
Mon Sep 14, 2015 10:02 am
It's not Florence that is the problem. The lower level events are stopping so any higher level toll will fail in the same way.
PeterO
jdb
Mon Sep 14, 2015 12:52 pm
We have seen this issue and are currently investigating.
Rockets are loud.
https://astro-pi.org
PeterO
Mon Sep 14, 2015 12:58 pm
jdb wrote:We have seen this issue and are currently investigating.
It seems quite "random". Sometimes only running for a few minutes and then after I posted this my Pi ran for the rest of the evening without stopping.
Running evtest will show you if it has failed as the stream of events stops.
I tried unloading and reloading the kernel module but it doesn't fix things :-(
PeterO
PeterO
Mon Sep 14, 2015 3:21 pm
billintad
Tue Sep 15, 2015 9:11 am
Using the file manager: touches on an icon do not seem to work consistently. Touches on the directory tree work and using the cursor keys works.
PeterO
Tue Sep 15, 2015 9:35 am
billintad wrote:Using the file manager: touches on an icon do not seem to work consistently. Touches on the directory tree work and using the cursor keys works.
Off topic. Please start a new thread for problems with applications.
PeterO
alexeames
Tue Sep 15, 2015 1:50 pm
Peter do you deem this issue solved yet or is it too early to say?
Alex Eames RasPi.TV, RasP.iO
PeterO
Tue Sep 15, 2015 2:27 pm
I think it should be left open until the updated firmware gets into the normal update. Until that happens people may still run into this problem.
PeterO
