jarrah31
STICKY: Official Touchscreen Display FAQ
Fri Sep 11, 2015 7:31 pm
Can the display turn off after x minutes and then be reactivated by just touching the screen, both in command line and in startx?
Thanks.
billintad
Re: Official Touchscreen Display Questions
Fri Sep 11, 2015 11:02 pm
I think you are supposed to use "Recommended peripherals", but a forum dedicated to "screens" might be a good idea as there have been many threads about that topic.
The desktop display (startx) does go blank after a period of no input . It is immediately refreshed by just touching the screen. I suppose there must be a parameter somewhere that controls the length of time spent waiting for input. I haven't looked.
I have not experienced screen blanking when the command line is being used, but I don't use the command line for any length of time. I will just leave it running for a while and see what happens.
billintad
Sat Sep 12, 2015 6:34 am
It would appear it does blank the screen when in command line mode, but I had to use the keyboard to refresh the screen. Touching the screen did not work.
jarrah31
Sat Sep 12, 2015 10:44 am
Thanks! I should have just left it running to see (though I did try to find screen saver options in the GUI first).
PrivacyEnhanced
Sat Sep 12, 2015 2:13 pm
Users have been complaining about X blanking for at least 15 years. Apparently nobody is listening.
PeterO
Sun Sep 13, 2015 7:26 pm
Do you have one of the new displays Dougie ?
PeterO
Sun Sep 13, 2015 10:07 pm
PeterO wrote: Do you have one of the new displays Dougie ?
I'm still discussing it with SWMBO, the household finance director.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
alexeames
Mon Sep 14, 2015 9:34 pm
You should get one. They're really nice :) Good price too.
Alex Eames RasPi.TV, RasP.iO
IngoP
Re: Official Touchscreen Display FAQ
Wed Sep 16, 2015 8:36 am
Hi.
after display has been installed my PiDAC+ won´t work any more.
No Audio Signal.
Would be there an issue by powersupply via GPIO ?
IngoP
Thu Sep 17, 2015 7:53 am
Hi.
Yesterday evening I disconnected official 7 ´´ RPI Touchscreen from my PI2.
After that my DAC+ works as well as before.
In my opinion there is an issue with power supply of PI2, DAC+ and Screen.
My PI is powered by micro USB 5V 3A by a regulated power supply. Touchscreen and DAC+ was powerd by GPIO.
Current of PI and DAC+ has been 0,40 A - 0,49A. at connecting display current will rise to 0,91 A.
So there is a question to be diskussed :
Is it possible do power PI2 and DAC+ via micro USB and touchscreen via separate wires from power supply ?
gsh
Thu Sep 17, 2015 8:30 am
Does the red LED on the Raspberry Pi go out? If so then the problem is the voltage to the Pi is dropping out.
Otherwise it is possible that the introduction of the screen is fouling the DAC I2C communications
Gordon
Gordon Hollingworth PhD
Raspberry Pi - Director of Software Engineering
IngoP
Thu Sep 17, 2015 8:54 am
Hi, no red LED is continuosly on.
what about your idea :
"...introduction of the screen is fouling the DAC I2C communications"
how could this be fixed?
meigrafd
Mon Sep 21, 2015 9:26 am
Is there an ETA when the Documentation for the Display get published / updated ?
Spezial i mean the available config.txt Settings and the Hardware Details.
Thanx!
gsh
Mon Sep 21, 2015 10:55 am
https://www.raspberrypi.org/documentati ... /Readme.md
Contains the first stab at information...
You can create github issues to ask for specific information items
Gordon
meigrafd
Mon Sep 21, 2015 11:41 am
Basically I meant more specifically Details - e.g. all possible config.txt settings
But now im confused... In the Blog stands:
70 degree viewing angle
But in that official Readme.md stands:
140 degree viewing angle horizontal, 130 degree vertical
Whats now correct?
gsh
Mon Sep 21, 2015 1:10 pm
It depends upon how you define viewing angle, the actual spec is
70 degree left
70 degree right
70 degree top
60 degree bottom
so total viewing angle is 140 horizontally, but 130 degrees vertically
Gordon
meigrafd
Mon Sep 21, 2015 2:03 pm
Is that from before or after the latest Firmware-update?
Because after the Firmware was flipped upside down top and bottom angle is also flipped?
E.g.: Before:
70 degree top
60 degree bottom
Now:
60 degree top
70 degree bottom
gsh
Mon Sep 21, 2015 2:19 pm
No that's why it was flipped!
Originally we had the display upside down, which made the top viewing angle only 60 degree...
Now with the display the correct way up it is 70 degree up 60 degree down
meigrafd
Mon Sep 21, 2015 10:21 pm
Ah oke, Thanks :)
Another Question: Is it possible to display on both Video-Outputs the same Stuff , and with different Resolutions?
E.g.:
HDMI -> LXDE
DSI -> LXDE
both the same Screen?
gsh
Tue Sep 22, 2015 5:42 am
Basically that would have to be done in X because it is the thing that draws in the windows and would therefore need to know about two different resolutions... And I'm fairly sure that X has no way of doing this!
It would actually be really hard no matter what system to had because you'd have to manipulate all coordinates and font sizes to draw the same thing at different resolutions!
Drawing everything at one resolution (800x480) and then rescaling to fit on the HDMI would work but work look terrible (plus there's currently no support for it)
Gordon
jorabo
Tue Sep 22, 2015 9:52 am
How to switch off the backlight ? And what is this "INT" pin for ?
If I shut down the RPI2 with the Display connected, the backlight keeps switched on...
After some time it shows funny stripes, because there is no further control for the display. :roll:
Is there a possibility to switch of the backlight separate ?
Anybody here knows the function of this INT pin ?
PS: The Readme.md is not longer avail...... Is there any official doc for the display ?
meigrafd
Tue Sep 22, 2015 12:03 pm
gsh wrote:Basically that would have to be done in X because it is the thing that draws in the windows and would therefore need to know about two different resolutions... And I'm fairly sure that X has no way of doing this!
Hm oke. And how would it be with XBMC on the DSI-Display and Video-Output over HDMI? By selecting the Movie over DSI-Display and playback comes over HDMI? ;)
Also i actually dont understand how i can switcch between both Outputs E.g. running mplayer over commandline
@ jorabo: For me the Readme is still available.
And also have a look here: viewtopic.php?p=816276#p816276
gadgetoid
Tue Sep 22, 2015 4:30 pm
gsh wrote:https://www.raspberrypi.org/documentati ... /Readme.md
Gordon
Raised: https://github.com/raspberrypi/documentation/issues/255
I've even collated most, if not all, of the requested information: http://forums.pimoroni.com/t/official-7 ... en-faq/959
Paul Webster
Contact: Twitter
Sat Sep 26, 2015 6:57 pm
Raspberry Pi Swag store description has been updated to state that the old model B and A not currently supported - and lead time for shipment of the display from them is set to 6 weeks (for orders from September 18th).
It does not yet refer to the upside down issue with the frame (leading to sub-optimal viewing) but perhaps the lead time will be long enough for the folks at Pimoroni to work out a solution (they have said that they hope to get onto it soon).
http://swag.raspberrypi.org/collections ... en-display
weleavefossils
Sat Oct 03, 2015 12:37 am
Upgraded to Jesse today and noticed that when I boot to UI with startx, the UI doesn't fill the whole screen and some menus don't allow me to view/select options that are too far to the bottom. I didn't noticed this before Jesse but I could be wrong.
Return to “Official Foundation Display”
